Which size tires should I run?
With my 20" wheels about to arrive, I'm debating which size tires to run.
Here are the two choices:
1) 255/35/20 & 285/30/20
2) 255/30/20 & 285/25/20
It's all about the profile size. I know the lower profile looks better, but having more rubber on my sidewalls might keep these wheels out of harms way for the next couple of years.
What do you guys think?
My Ride: .
Model Year: .
EDIT:
Plus, isn't set-up #1 the right sidewall ratio for the M5?
Btw, can you go 295 on the rear?
Originally Posted by mrfva' post='667195' date='Sep 11 2008, 03:23 PM
+1 on #1 set-up. I'd run those if I wouldn't rub, but I'm just a lowly E60, not an M5 ![Tongue](https://5series.net/forums/images/smilies/imported/tongue.gif)
EDIT:
EDIT:
Member EuroCarFan and Nigxdoof have the 35/30 profile set-up on their RAD's. However, poleposition and a bunch of others have 30/25 on their 20's.
You don't win anything with wider front tires - 255/30/20
Rears can be a bit wider, but too wide is not good for anything - 295/25/20
Those tires would be within the OEM specs, but don't drive into potholes.
The wheels should be suitable for the tires, F 9.0 and R 10
and the ET's right, F about 12 and R about 28 (look out for rubbing).
The tires should also have "rim defence".
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Calton,
You can't run option #2. If you do, you'll be out of BMW specifications. E60 M5s are designed to have a larger rolling diameter than regular e60s, so 255/35/20 and 285/30/20 for you.
My Ride: .
Model Year: .
Originally Posted by C's Bimmer' post='667202' date='Sep 11 2008, 02:27 PM
I can do 295 in the rear, but I would then have to do a 25 profile tire in the rear and 30 in the front.
Originally Posted by vegastrashed' post='667248' date='Sep 11 2008, 04:07 PM
Calton,
