Shock absorber + springs
Old Mar 19, 2008 | 12:31 AM
AlexFW's Avatar
Model Year: 2005
Good morning guys!
I have sport suspension + Dynamic Drive Control (Active Roll etc. named is USA)
I have to replace rear shock absorber and I am considering to don't get BMW parts .
So what should I get ?
I know many solutions are not suitable for sport suspension/DDC .
I would like to correct the shock at 06.11 (of the 545i obviously, the grey E60 in this video) .
Which is your experience ?
What could I buy for my 5 ?
Something adjustable ? Model and brand ?
Your opinion pls!
Thanks
Old Mar 19, 2008 | 01:07 AM
delje08's Avatar
My Ride: 545i
I have Bilstein PSS9 coilovers, you can adjust the height and ride quality from comfort to aggressive. After installing these puppies in my opinion i thought it was better with comfort than my previous setup of H&R sport springs and stock sport shocks.
Old Mar 19, 2008 | 01:10 AM
AlexFW's Avatar
Model Year: 2005
And compared to the stock situation ? Which set up did you have from factory, sport suspension+ddc/ars ?
Old Mar 19, 2008 | 01:29 AM
delje08's Avatar
My Ride: 545i
Same as yours.
Old Mar 19, 2008 | 01:42 AM
AlexFW's Avatar
Model Year: 2005
What different between PPS and PSS9 ?
Old Mar 19, 2008 | 01:55 AM
delje08's Avatar
My Ride: 545i
Do you mean PSS, if so the difference is PSS is only height adjustments and PSS9 is height and stiffness adjustments.
Old Mar 19, 2008 | 03:00 AM
AlexFW's Avatar
Model Year: 2005
They are cheaper indeed.
The dealer just suggested Msport suspension retrofit:
http://bmwfans.info/original/E60/Lim/545i-...33/ill-33_1339/
Is it suitable for my car in your opinion ?
Reading "msport" sounds more... OEM.
But likely they won't be adjustable as bilstein (?)
Old Mar 19, 2008 | 05:10 AM
bmw_wpq31's Avatar
My Ride: MY2005 E60 525i M Sports
Try KW V2 coilovers...their height + stiffness adjustable too...i've been using them for more than a year now and their still great...
my car came with msport suspensions, but i didn't like the height of it...
Old Mar 19, 2008 | 09:33 AM
AlexFW's Avatar
Model Year: 2005
Excuse me guys, but I heard the OEM absorber should be adjustable too. Is it right?
I could be satisfied with my sport suspension a little stiffer . At the rear, the front ones are ok for my taste .
Do you know if it is doable ?
Old Mar 19, 2008 | 10:28 AM
southgate's Avatar
nice vid
