Serious question about sprint booster
Old 03-25-2009, 05:32 AM
porsche911targa's Avatar
Has anybody experienced a higher rate of tranny lurch or slam after installing the sprint booster? Do you find that you need to reset the tranny often?
Old 03-25-2009, 06:56 AM
e6t.lab.rat's Avatar
just installed mine and not quite as thrilled with it like most other folks. i didn't necessarily get a higher rate of slam, just nothing noticebly different during street driving. still got the hesitation. it's great during higway speeds (quicker throttle response), but still got the lag from stop.
i've already done one reset....hopefully i'll see results after a few more miles.
Old 03-25-2009, 07:22 AM
Krozi's Avatar
My car feels like it stubbles sometimes when going from a stop. Is this normal though?
The car won't stumble if I gradually give it gas or if I really give it gas, just when I give normal gas.
C's Bimmer's Avatar
Don't get it. It's a waste.
Old 03-25-2009, 08:57 AM
xBMWx's Avatar
I did for a short while with my previous ride the LCI 525d auto; it started happening a few months after install, but after a few tranny resets it was fine. It confused me for a while, but just seemed to sort itself out after a week or two (can't remember precisely) and I then never had issues with tranny slam again. I have had no issues with this on my current 530d auto
Old 03-25-2009, 12:21 PM
mistique_M3's Avatar
I just had mine installed today and i have to agree with e6t.lab.rat not very impressed...what is this about having to reset the tranny? Sounds expensive? Is this something only the dealer can do? if so is it covered under warranty if you have the SB installed?
Old 03-25-2009, 12:24 PM
CWS530's Avatar
http://forums.e60.net/lofiversion/index.php/t69344.html
Old 03-25-2009, 12:25 PM
Krozi's Avatar
All you have to do to reset the tranny is sit in the car. Buckle up. Put the key in ignition position 2 (engine off)
and hold down the gas pedal all the way down for 35 seconds.
Sounds expensive but it's not
Ahh you beat me to it CSW530
Old 03-25-2009, 12:27 PM
flyingpuck's Avatar
My transmission was slamming before the Sprint Booster, it made no difference in the frequency of slams at all! Now with the new transmission, it does NOT slam at all, and the Sprint Booster just keeps on delivering smiles!!!
Old 03-25-2009, 12:43 PM
Banned
ynottony's Avatar
Here are the instructions from the link that guy listed above:
Try using the transmission reset trick. You can use the search bar for more threads....
Basically you put the key in the ignition, push the start button without stepping on the brakes.
Hold down the gas pedal for 30 seconds and the transmission resets.
Start the car and the car will 're-learn' your driving style/habbits.
Which instructions are correct? Do you hit the start button or not? Do you push the key in all the way?
Quick Reply: Serious question about sprint booster
