Selector Lever Replacement
My Ride: 2004 Jet Black 545i
Just had my shifter knob replaced at BMW. The finish seems to be more of a Matte than smooth like my other one. I did a check on RealOEM and came up with these two part numbers. Is there any way to see if they gave me the wrong knob, or are the new knobs just made this way?
Here is a link to RealOEM:
http://www.realoem.com/bmw/showparts.do?mo...hg=25&fg=25
Then I googled 25167522366 and it shows on Circle BMW's site, but 25167522365 does not..
http://www.circlebmw.com/cgi-bin/acc/acc.c..._records=Search
Thanks in advance..
Thanks in advance..
My Ride: G30 M550i
Model Year: 2018
Usually, the part numbers are stamped somewhere on the part. You might consider removing the shift knob to see if the number is readable somewhere on it.
If you need directions on how to remove the knob, take a look here:
http://forums.e60.net/index.php?showtopic=16303
