Sealed Key Fob
My Ride: E60 550i, Ducati 748
On the back side there is a cover that you pop off and the battery is in there, Pull the key out of the fob and you can see the notch where you pop it out.
My Ride: 525M Sports Tourer 3.0D
The sealed keyfob recharges as you drive, what makes you think you need to replace battery?
(To answer you question you can't without some serious effort and soldering skills)
My soldering skills are not that bad either.
Well in that case ![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
Part
http://hqrp.com/hqrp-rechargeable-ba...-key-fobs.html
Dissection
http://www.bimmerfest.com/forums/sho...d.php?t=480795
Part
Dissection
Part
Dissection
Part
Dissection
If I can locate the battery I might just give this a go.
thanks for your help
Wonky
04-12-2016 08:15 PM
