Can anybody tell me how to change the battery on a 2007 key fob without going through BMW
On the back side there is a cover that you pop off and the battery is in there, Pull the key out of the fob and you can see the notch where you pop it out.
Originally Posted by E60_550i
(Post 1440281)
Its totally sealed. |
The sealed keyfob recharges as you drive, what makes you think you need to replace battery?
(To answer you question you can't without some serious effort and soldering skills) |
Originally Posted by bcromwell
(Post 1440287)
(To answer you question you can't without some serious effort and soldering skills) My soldering skills are not that bad either. |
Well in that case ;)
Part http://hqrp.com/hqrp-rechargeable-ba...-key-fobs.html Dissection http://www.bimmerfest.com/forums/sho...d.php?t=480795 |
(Post 1440291)
Part http://hqrp.com/hqrp-rechargeable-ba...-key-fobs.html Dissection http://www.bimmerfest.com/forums/sho...d.php?t=480795 If I can locate the battery I might just give this a go. thanks for your help |
