SAT NAV RETROFIT advice needed for 2006 E61
#21
I have a 525i and its not wired for satellite. What parts do I need? I saw this on ebay, but are there any additional parts?
http://cgi.ebay.com/ebaymotors/BMW-E60-545...5fAudioQ5fVideo
#22
My Ride: 520d M Sport
Titanium Silver
Retro fit's -
Professional Sat Nav
Footwell Lights
BMW Bluetooth
LCI Halogens with HID
Thats pretty much what you will need but also you will need the front fascia trim and fan cable both i got from my BMW dealer
#23
Titanium Silver
Retro fit's -
Footwell Lights
BMW Bluetooth
BUMP
Installed Professional Navigation today original.gif (Thanks wokingBigBoy for your help and advice) all is working and no coding required.
i went for a slightly older unit so i would not have any coding issues.
but i notice i dont have POIs like filling stations etc and i dont have the 3d view, does my car require a software update from the dealers to enable these.
Also 7 digit postcode was this with the latest DVD i am using 08-01
#24
Originally Posted by livefour2day' post='1016952' date='Sep 25 2009, 02:10 PM
BUMP
#25
Hi, I am planning the same upgrade.. Can I use the 8.8" monitor from fore instance 2007 in my 2004 model or shall I look for a monitor with the same build data or does every professional monitor fit regardless of production date?
#26
My Ride: 530d Sport Touring, Titanium Silver, HiFi Loudspeaker system, Heated Front Seats, Tracker Retrieve, Media Package, Black Dakota Leather & Steptronic Transmission
Originally Posted by livefour2day' post='1016817' date='Sep 25 2009, 05:19 PM
Installed Professional Navigation today (Thanks wokingBigBoy for your help and advice) all is working and no coding required.
#27
My Ride: 545 SE Auto in Black
Originally Posted by kkrazykool' post='1035755' date='Oct 19 2009, 05:19 PM
Hi there, I suspect my sat nav pro requires replacing, I am interested in knowing where you sourced your new head-unit from and also how difficult it was... many thanks!
#28
My Ride: 06' 530xi E61 Saphire Black / Dakota Black - aluminum
11' A4 Avant 2.0T Brilliant Black / Black - aluminum
Hi sorry to revive this thread just picked up an '06 E61 530xi and was considering retofiting the GPS system.
I have found a unit model #65836962545 I beleive it would work ? I realise I will need an antenna and the wiring harness as well + programming.
Any help confirming this would be appreciated.
#30
Please can someone explain the colour coding for the fan harness cable:
#61120396722 --ccc fan cable
RTSW cable to PIN 1
BR cable to PIN 5
WS cable to PIN 11
I need clarification on what RTSW/BR/WS mean. The unit is working but after about a hour of driving the CCC unit seems to heat the SAT NAV DVD and if you put another location in I normally get a read error so I think I may of wired the fan up wrong.
Thanks
RTSW cable to PIN 1
BR cable to PIN 5
WS cable to PIN 11
Thanks
RTSW 1 fan pos To 1 fan positive
WS 2 diagnose to 11 diagnose
BRSW 3 fan negative to 5 fan negative
The left is the small connector that connects to the fan and the right side is the large 13813 connector for back of CCC.
tom333
04-01-2015 01:56 PM
