retrofit Digital TV tuner manual
#52
Guest
Posts: n/a
iceman,
I have my settop box received. Opened it and found out that it is correct that 2 have two AV inputs:
like I see it (regarding to th chips) it is 2 video-green in and 1 audio-brown in (left and right). I have read that the board is coming anyway with a 2 AV in and that the digital is not completely digital.
it uses a pass trought with the antenna, so he puts a antenna signal on the line.
The connectors are the normal BMW antenna connectors. Can be found in every audio shop.
Maybe this can help you already. I am wiating for my installation date(I ordered more). I think it will be next month.
#55
Originally Posted by Iceman' date='Mar 27 2005, 04:44 AM
???? I dont understand why you putted the pictures again on it ?
I openend the box and looked inside
#56
My Ride: F02 LCI Individual
Model Year: 2013
[snapback]108067[/snapback]
It dissappeared...
Anyways.
I see the brown and green connectors. But they are not cinch, so I need connectors that allow me to plug in a PS2 or a DVD player.
And why are there two video inputs with two audio inputs? The two audios are right and left... The video???
#57
Guest
Posts: n/a
each connector has a + ( the pin inside) and min (the shield).
- the green connectors: 2 connectors=2 video in (= you can add 2 devices: example: A PS2 and a DVD player but you need to connect the audio of each other to the brown inputs (it seems 1 for left and 1 for right).
Dont focus on the green an brown (these are just easy clickings). Look into the brown and Green and than you will see that these are normal BMW antenna connectors(=have also a pin and a shield) that are being used to connect the Antenna towards the CCC for receiving FM signal (can be found at the back of the CCC).
When you do a search on the internet you will find the bmw antenna connectors or just ask your dealer. He should have them.
(Greetings from De_smet_h
#58
Model Year: 2013
Thanks, De_smet_h!
My dealer is allready nervous, because he is not getting any info from BMW and can't talk me out of it...
#60
Model Year: 2013
Originally Posted by Guest' date='Apr 13 2005, 03:31 PM
Iceman,
in the settop box menu, can you choose an aux or multiple aux ?
Can you put a picture of this on the forum site ?
thanks (de_smet_h)
thanks (de_smet_h)
[snapback]114856[/snapback]
In the menu I have one option: activate AUX Input.
Don't have a pic of it yet, will try to take one...
