Replica Trinity Sideskirt Install questions
Old Mar 11, 2010 | 06:19 AM
D33ZNUT5's Avatar
My Ride: 2006 titanium silver metallic Like new 41k Cold Weather Package
So I found this DIY that has PDF instructions and am unsure if the skirts from Trinity install exactly the same as the OEM skirts or is there custom fabrication required? I'm hoping to tackle this myself rather then paying a shop to do it.
Anyone else done this or would you recommend a shop? Should I buy new clips or reuse the old? Will the replica skirts have marking to show me exactly where to position the new clips? I don't see any mention of using glue so I asume they just pop off and on?
https://5series.net/forums/topic/382...age__hl__mtech
Old Mar 11, 2010 | 06:36 AM
pjinca's Avatar
When Trinity's shop did mine they had to do no modification or fabrication and the install went exactly the reverse if the removal. I think if you're careful (they are painted right?) and take your time the install will go smoothly. Good luck and remember: PICS or it never happened, don't be a Vlad.
Old Mar 11, 2010 | 08:08 AM
D33ZNUT5's Avatar
Don't worry there will be pics, I plan on whoring it up this year I'm super stoked that we have the earliest spring on record this year, I can already see grass on my lawn
I'm praying that everything works out since I am getting them prepainted! Would you recommend new clips or are the old fine?
Old Mar 11, 2010 | 08:14 AM
pjinca's Avatar
New/old clips are really up to you. For mine they reused the clips and it has worked out fine, they have been on for several months now and the fitment is still about as good as I could have expected.
Old Mar 11, 2010 | 08:38 AM
yes install is exactly the same. the clips and screws from your stock side skirts just need to be transferred and used on our replica mtech side skirts.
Old Mar 11, 2010 | 10:15 AM
White5's Avatar
I call shenanigans!
Jk, you shouldn't have any problems. Did it myself and it was like BUttER.
Old Mar 11, 2010 | 11:19 AM
melimel's Avatar
Originally Posted by White5
I call shenanigans!
i should be able to do it too then.. my skirt should be done in about a week or less. im not in a rush as im also waiting on some other parts i just ordered from tischer..
windnsea
May 25, 2015 09:49 PM
jwdominick
May 19, 2015 02:50 PM
carid
Apr 29, 2015 04:20 AM
doughboy540
Mar 26, 2015 02:05 PM
brian1225
Apr 16, 2004 05:59 AM
