Replace Audio AUX with USB for Music?
My Ride: 530xi Wagon
Engine: n52
Hi all
I have a 2007 E61 530xi. I'm currently using the AUX port on the center console for audio from my phone, but I'd really like to get better sound quality that goes with a direct USB connection. I found this on BMW's site: pn 84109237656 https://shop.bmw.ca/p/BMW__/USB-sock...109237656.html
The image on that link doesn't seem to be the right one - it's a USB port. It seems obvious that this would work for audio phone calls, but has anyone installed it for music?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I installed a Bluetooth 5.2 chip on my aux line behind the dash. It's been perfect for the last 3 years. When the phone rings it stops playing so you can answer the phone. The only thing is you can't change songs with your steering wheel. It didn't bother me because I hardly use the wheel buttons. I don't even know if there's a USB solution for music. I would assume the signal wouldn't be able to be read but the CCC
Administrator
I used to have a Phatbox in my E39, which was basically a hard drive that played MP3s. You could select songs by artist, album, genre or shuffle, all controlled by the steering wheel. I had over 700 songs on it. When I upgraded to the E60, the Phatbox wasn't compatible, so I looked at the Dension Gateway so I could do the same thing, but just never pulled the trigger. Once I discovered Bluetooth, it was a much cheaper solution, and I decided that having a dash mount for my phone worked nearly as well.
Engine: n52
Hm. The Denison Gateway is interesting. It says it doesn't work for Japanese models though so it probably won't work for me unfortunately. I have a Japanese import left hand drive E61 obviously meant for sale in Japan with Japanese stickers and a Japanese manual. I'm not sure if the LHD models were just Euro models exported to Japan or if there is something specific to them.
buzzkill911
Bluetooth & Cell Phone Forum
14
02-19-2015 02:45 AM
