Rear Aux Tap
Old May 31, 2011 | 10:23 AM
T1000BP's Avatar
My Ride: 550i M SPORT - 6 SPEED MANUAL
I'm in the middle of adding the xCarLink Video Source module.
My car came with the factory rear Aux input. I need to splice it since I don't really want a 3.5 mm sticking outta it for the video source module. Is there a spot where I can splice it somewhere up front so I don't have to run a wire from all the way in the back to my video source module in the glove? I like keeping things clean.
Thanks for your help guys!
Old Jul 19, 2011 | 07:45 AM
///MrSingh's Avatar
My Ride: 2007 E60 535d M Sport
Did you manage to do this? I've just bought the same xcarlink interface
Old Jul 19, 2011 | 10:19 AM
T1000BP's Avatar
I did. I just ran a wire under the center console to the rear aux. I opened up the back console pulled out the aux, plugged in my media interface to it and shoved it all behind the rear console. I replaced the hole it created with a BLOCK OFF PLATE which I ordered from BMW. Works like a charm. Check out my post.
https://5series.net/forums/topic/114...2#entry1352662
Old Jul 19, 2011 | 12:16 PM
///MrSingh's Avatar
Ah ok, so you didn't actually tap into it, just plugged straight into the actual socket using a 3.5mm jack?
Old Jul 19, 2011 | 01:06 PM
T1000BP's Avatar
Exactly. I just used the media players other input as a secondary aux.
Kasmo
May 7, 2019 03:30 AM
UltimatePeter
DIY: Do It Yourself
Sep 28, 2015 09:12 AM
coreybunz
May 1, 2015 07:24 AM
kennethnoel
Apr 7, 2015 06:17 AM
Sammie973
Bluetooth & Cell Phone Forum
Mar 12, 2015 06:51 PM
