Re-fitting Headlight Unit - Alignment / Seating Issues
My Ride: 535d Sport
Ok guys. I just did both of mine last night. 2010 550i M sport
You need to have a 6 inch T6 to do this. Also a magnet with an extending handle. Available cheap at any auto parts store. Leave the inboard lower bolt as loose as possible, and remove the outboard lower bolt completely. Install the headlight favoring the inboard side making sure the lower bracket slides under the bolt. Position correctly and tighten the upper bolts and the one lower bolt. Now use the magnet to lower the lower outboard bolt into place and give a turn or so to get it started. Now use your 6 inch T6 to tighten the lower bolt. No need for tiny hands,
Cheers!
DavaiLave
08-02-2022 02:16 AM
TexaZ3
05-06-2015 09:54 AM
