Questions regarding Software update using WinKFP
I am thinking of doing a software update on necessary modules via WinKFP and DCAN cable.
The first thing I did was to get the UIF information from INPA, then compare it with the Daten files I have using WinKFP. Here is where I have couple of questions.
For every module
Assembly Identification # == Hardware # --> no update available
Assebmly Identification # > Hardware # --> update available
Assembly Identification # < Hardware # --> what does this mean?
Also what does it mean if WinKFP cant find a ZUSB#? Specifically in my case it is not able to find 9262360
And my FAS and BFS modules have same ZB#, does that mean they are associated to the same module?
In the UIF output, for some modules, the VIN# is either unknown or 0, what does this mean? Is it communication errors or they were not programmed properly?
thanks
For every module
thanks
My Ride: E60
Hi, I've been fighting with a DME for a while now. Maybe we can help eachother out. I updated and changed my VIN just today and it is pretty involved using WinKFP. I can do a GM in 20 minutes, but these BMWs are a test sometimes. Hehehe
Be sure you can connect and read everything with INPA first. Using INPA, you can get all the info you need to get started in WinKFP. I'm not sure what the latest ZUSB# is, but my Autel says 78xxxxx and I am currently at 7611551. I was mostly interested in changing the VIN from a used DME. My next project is mating it to my CAS to get the car started.
There are different version of daten files online, some say V4x and some say V6x, not sure which one is the latest one !huh!
My Ride: E60
Engine: 530d
Honest advice: If you don't know what you're doing (this includes: If you're not 100% sure what you're doing), don't do it.
You can easily fry an ECU.
Thanks for your advice Chris, I am aware of the problems and have read many posts where people messed up their ECUs. But one has to start somewhere and for me would like to know most of it before trying to do anything. Still looking for answers for my questions though.
wokingBigBoy
02-11-2018 07:56 PM
Moimotref
01-24-2017 03:44 PM
MTL545i
05-04-2008 09:36 AM
