Question on Aux Input
Old Dec 14, 2005 | 06:09 PM
znod's Avatar
Originally Posted by das' post='211310
My bad, but at least I warned. You still would be able to connect a CD player, right?--even though the input is analog?
A 1/8" audio jack is a 1/8" audio jack; it is always analog, and the output from any CD player via a 1/8" audio jack will always be analog. It could be "line level" (unamplified with no volume control) or "headphone level" (for headphones, with volume control on the device), but it's still analog. (Some manufacturers embed a digital/optical connection inside of what appears to be a 1/8" audio jack, but a "true" 1/8" audio jack is always analog.)[/quote]
Thanks das. I quess it won't do me any good to hook an SACD or DVD audio player to the AUX. I do wish we had one or the other or a both-in-one player in the single slot to go with the L7--assuming L7 would play all the channels. Would it? As mentioned, I think L7 will play multichannel, for example, SIRIUS broadcasts. Right?
Old Dec 16, 2005 | 07:50 AM
ajay's Avatar
My Ride: 2004 BMW 525i, Titanium Silver, Black Dakota Interior w/poplar wood trim, Tinted Windows, Premium Package, Cold Weather Package, Stick-shift, Bluetooth, AUX Input
Thanks a lot guys... Right now I'm using the normal stereo jack... may be thats why the fit is not perfect... I'll try the 1/8" jack and see...
[/quote]I can't help you with the details because I have not fooled with the Aux. Some need to have some sort of retro fit to use their iPods.
[/quote]
I dont think there is any retrofit to be done to make the iPod work,,, its just another mp3 player... as long as you plug in hte audio output to the aux input.. it works fine..
Old Dec 16, 2005 | 08:09 AM
cobradav's Avatar
Actually on a TV or DVD player you would need the AUX Input and cable connection to get the audio portion into the sound system. Any device that has an headset or line out could be connected. I use a cassette player often times, I have old portable CD players also will interface with aux, and if you had a portable CD changer you could use that as well, provided it has a output connector. Most any brand of MP3 player works as well. Even PDAs with a headset output could be connected. I believe stream covered most of this as well.
star69me
Jun 17, 2015 07:40 PM
Sammie973
Bluetooth & Cell Phone Forum
Mar 12, 2015 06:51 PM
Doctor Diesel
Jun 13, 2004 09:25 AM
JohanDC
May 3, 2004 03:40 PM
