problem with oem m5 mirror
Hello guys,
so i got m5 mirrors on... but i think im missing a part... when i look at mirror, there are two wire connector available on the back side of mirror... i think i need some kind of part that would fit 4 pin wire to 2 pin connector on mirror ...
if anyone knows let me know
Thanks!!!
Thanks!!!
My Ride: 2007 550, premium, sport, nav, bluetooth, satellite, cold, M5/Mtech front bumper and side skirts, matte black kidney grilles, M5 fender grilles, M5 mirrors, euro stickers, 35% tint, 20" Miro 111s (summer), 18" VMR VB3s w/ 10 mm H&R spacers (winter)
Are they OEM or the NVD reps?
My Ride: 2008 535i Space Gray Metallic, Black Dakota Leather, Sport Package, Premium Package, Navi, Automatic. HID 10000K Angel Eyes, 8000K Low Beam and Fog Lights... Next up: MTech Kit, Sound System and Backup Camera, and maybe some new shoes!!
So did you get the mirrors and glasses from separate sources? The reason I ask is that your mirror seems to be only the normal heated version. However the electronics seem to be from a mirrors seem to expect a mirror with heating and electrochromatic glasses.
So before I suggest what you need to do can I just confirm if the 4 wire connect is on the mirror glass or coming from the mirror. Either way you can get this to work but you are going to have to hack this. The 4 wire connector used on the M5 mirror is not sold as spares and not even manufactured by Tyco, its made by a company called Hirschmann. You won't believe that it took me a good part of 2 years to find out this.
The M5 mirrors I made up for Sanj used those connectors to acheive a completely plug and play solution.
In case your mirror has just the 2 pins, then those connectors are also not sold as spares but you can use miniature female space crimps e.g. http://www.maplin.co.uk/Module.aspx?ModuleNo=34145
See https://5series.net/forums/topic/548..._1#entry578961
From the mirror you will have four wires coming to connect to the mirror.
VIOLET/BLACK: For the EC mirror
RED/BROWN: heated mirrors
You need to connect the Red and Brown wires to the mirror glass using small female spades.
Stormcrow
12-01-2019 02:09 AM
