Predator Ice V2 - Resistor Issues
Old Apr 11, 2010 | 12:23 PM
travis's Avatar
So I bought a used set of these and all was well for like one day. I noticed that one side had burnt out and thought, ok the resistor might have went bad considering the fact I bought the set used. I then bought a replacement resistor, plugged it in.....nothing. I took the same resistor plugged it into the other side, and it wouldn't work either. Correction, it would work, but only if I pressed down very hard to squeeze the connection from the bulb to the resistor really tightly. So I summized that is wasn't the bulb connection it was the resistors b/c I still had the old one and the new resistor I had bought and they both are this way. Anyone else bought a resistor and the fitment was just off, is there a way I could configure it to work. I already tried filing down the resistor connection and that didn't do it. I have also contacted Umnitza to see if they had an answer and to see if they would just replace the resistor for me but haven't heard back. I have already put too much money in this mod to keep throwing money at a resistor at $25 a pop.
PS. The other resistor I have works on either bulb with NO issue.....weird.
PSS. If anyone wants this used set of Predator ICE V2 bulbs at a big discount, let me know. I know they work, just need a resistor that will do the trick on them .
Old Apr 11, 2010 | 07:59 PM
/\/\5power's Avatar
My Ride: M5
Sorry to hear that, They worked fine when I had them. I just upgraded to the Mtec V2s because they were brighter. Are you sure the connection is good, I had mine installed from the shop with no problems.
Old Apr 12, 2010 | 04:33 AM
travis's Avatar
Yeah I am positive the connection is good, there's something with the resistors I believe. No worries, I am just going to sell them anyway to get the Mtech V2's.
FCman
May 24, 2015 12:53 PM
Margal
May 19, 2015 09:25 AM
kmrod
Apr 25, 2015 10:00 PM
bimmermadness
Apr 24, 2015 01:13 PM
joeekrub
Mar 27, 2015 04:04 AM
