Pre-Lci Bi-xenon to Pre-Lci Adaptive Bi-xenon retrofit help
#31
Yep all the codes have been checked and added to the VO. More codes added with the retrofits. Suspecting a SMC errors or wiring at the headlamps... Will get another light module from a scrapyard to test out if a LM is faulty or not..
Edit---------
Could somebody dump a trc file from the LMA? I have a latest version at the module list if using a ncs dummy.
Edit---------
#32
Grab the file from this great mans post. Here is the URL
https://5series.net/forums/diy-do-yo...hanges-136756/
Edit---------
Edit---------
#33
I do have a working spare LM2 AHL, obviously if you want to pay the post and cost you can have it.
- However I believe the coding on yours needs to be redone.
- I can send you my TRC file, but i had to recode it to work with the rear LCI lights.
Edit---------
Edit---------
#34
Didn't had a chance to go to to scrapyard yet. Since it cleared the ALC system error in ista once I connected ground correctly I am thinking my SMC's are too new for a 2009 LM module.... Will see once I have a chance to swap them. Send me the trc file please.
#35
My TRC will not be the right one for you, unless you have rear LCI lights without Bruce cables. Also if you change the production 2007 and plus, your Mirror sensor will not communicate. Read this guys post, i would have never solved my issue if i never read it.
