Power wiring under the glove box
Hi guys
Does anyone know which wire under the glove box gives strong jumper power? I need 13-16V supply for equipment but can't find out which one gives strong power supply when the ignition is pushed on.
Thanks
Thanks
The fuse block is behind the glove box. I believe that the the top row of fuses is on all the time and the bottom row is switched. Use any space. Just use a stakon tab to stick in the upper part and put a inline fuse in the circuit.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by my530i' post='616691' date='Jul 5 2008, 12:15 AM
Grab power from power slot under passenger foot well.
Originally Posted by Rudy' post='616702' date='Jul 5 2008, 06:59 AM
I'm not sure that power slot/socket is standard on cars outside the USA...
Next question is which one should I connect my equipment to which uses 5Amp fuse or does it even matter which one I connect it to?
