Porsche Cayenne Brakes On e60
Old May 1, 2008 | 01:18 AM
marklim's Avatar
Hi Guys,
Been wondering for a long time. Is it possible to fit a cayenne stock brakes onto my e60 ?
And if possible, does it need to be modified or anything ?
Regards,
Mark
Old May 1, 2008 | 04:27 AM
BlueSander's Avatar
I have seen people put these on the Audi A4, which is a relatively small sedan compared to the E60. I think as long as you already have a 18 or larger rim, you should be okay.
Don't quote me on this though, let's wait and see what others say
Old May 1, 2008 | 06:40 AM
alpina04's Avatar
Old May 1, 2008 | 06:54 AM
luigi524td's Avatar
Originally Posted by marklim' post='572175' date='May 1 2008, 05:18 AM
Hi Guys,
Regards,
Mark
Are you experiencing a problem you think may be solved by installing "Porsche" brakes? Today's automobiles are pretty complex and besides calipers, rotors, and pads there are lots of electronics [ABS, Stability and Traction Control Systems] that are also involved.
As for others doing this on an Audi, as they are in the same "family", part interchanges probably are probably simpler?
Old May 1, 2008 | 07:19 AM
s4iscool's Avatar
My Ride: E90 330i + E60 550i
Id imagine that a custom carrier would have to be fabricated and the caliper/rotors would need to clear your wheels...with that you can use most calipers on most cars.
Old May 1, 2008 | 08:00 AM
flyingpuck's Avatar
Originally Posted by marklim' post='572175' date='May 1 2008, 02:18 AM
Hi Guys,
Regards,
Mark
Have you considered Brembos instead? It might be easier too!
Old May 1, 2008 | 08:24 AM
MikeBuzzsaw's Avatar
Interesting.....
Old May 1, 2008 | 09:20 AM
bigbadbull's Avatar
My Ride: 2010 VW Passat Wagon 2.0l Tsi Grey/Grey Budapest 18" Lost to HPFP issues: 08 535i sport pkg Lost to Dreaded E61 Sun roof leaks: 07 E61 530Xi
Yeah most Audi/ VW big break kits come from there new owners ( Porsche), funny thing is that the MKIV r32 front breaks are the same ones used on the 1995-6 BMW 7's form the middle east ( they are huge )
You might have some issues with the sensors , the Rain scrub, hill desent etc... also maybe with the Break resivour too.
The Cayenne Turbo/ and S breaks are huge! You will need some very big clearance on all the rims due to the calpiers being huge, and the rotors/disks are not small either.
Old May 1, 2008 | 09:45 AM
545felix's Avatar
My Ride: 05 545/6
Hi Guys,
Regards,
Mark
if you have 19" wheels, why not go for used M5 brakes? they are HUGE, dual piston, cross-drilled, and bolt right up. what more could you ask for?
Old May 1, 2008 | 10:02 AM
AlexFW's Avatar
Model Year: 2005
They are not so powerful to be honest, but they are the best solution: M5 to seriously improve the braking, but if you will go on track for an entire day you will need Brembo .
