poor radio reception after new amp install
I dont get it. first I added a self powered bazooka tube (which sucked btw) because at high volume the high end would cut off bass (only 100 amp powered tube) so tonight I install a single 10inch speaker box and a fosgate 1000db amp now the radio reception sucks. any ideas why ? I have a good ground and have great rca"s coming off inline converter good remote off stock amp ect... wasnt a problem with the tube ?????????
My Ride: 04 545i sport, stick, L7, sat, nav. Charcoal/ runflat/ cdv delete.
Suede headliner/ trunk, 3 way front speakers, four 8" subs in rear shelf, ACM, iPod dock in ash tray using gateway 500 with MP3 text and video on screen, MRTM aluminum pedals/ door pins, 10 farad cap, sound processor, line conditioner, 2 amps ( 4x100 and 2x200)
Sounds like the remote turn on you found "off the stock amp" is the power wire for the amplified antenna. What happens if you disconnect the remote turn on wire?
