Please Help: Will E46 M3 Wheels and Tires Fit on E60
![Help](https://5series.net/forums/images/smilies/imported/help.gif)
Thanks.
My Ride: '04 545iS 6 spd, bought new via eBay, 11/05; Blk/Gry, Cold, L7, PDC, BMW Rear seatcover for pets.
First "Bumwa" was a new 1971 2002. High performance 5s since 1987. Beamer motorcycles too, currently on an 07 BMW K1200 GT; also a Moto Guzzi 1000 SP III.
Thanks.
Ray Hull
[/quote]
Need to know the 2 size numbers to ballpark. My 235 45 17, E39 snows fit on the new 17 wheels I bought for E60 snow use. Minimal difference in ratio/aspect.
Ray Hull
[/quote]
Ray,
I am not worried about the tire sizes. They are very close because of the difference in diameter and profile. I am worried more about the wheel offset difference...
Ray Hull
[/quote]
Ray,
My Ride: 2006 530xiT Titanium Silver, 6-speed Manual, new style Start/Stop ignition, Black Dakota Leather, anthracite maple wood trim, heated seats front and rear, heated steering wheel, headlight washers, automatic tailgate, auto dimming mirrors, Logic 7, 6-disc changer, sport seats, shadow line trim, rear sun blinds, PDC, adaptive xenons, 18" style 123 wheels, , navigation, voice control, bluetooth, BMW roof rack + bike attachments,
Your M3 wheels will not work with the e60. They have different offsets. The M3 wheel has a et47 offset in the front and et26 rear. The e60 needs a et20 offset. If you want to split hairs, the rear wheels will fit but sit in little, but not by much.
Thanks.
I'm sure that your E46 wheels do not fit your E60.
Go only for wheels that have the correct offset!
The offset is different. But the offset is larger in the 3 series wheels (about 40mm for the three series and about 20mm for the 5 series). Therefore the 3 series wheels will sit is too far.
The solution may be 20mm spacers and they should work - assuming they fit on the hub.
If they do fit let me know because I have a 530xi and need the 40mm offset and it is hard to find 5 series wheels for the xi, but if they fit around the hub then 3 series will work. This would be helpful information for all e60/61 xi owners.
mikes 5
08-19-2015 06:12 PM
