Ordering BBS RXII Need advise on tire size
I haven't decide on the tire size. Rim size
19X8.5 F
19X10 R
I'm thinking to put 245/40/19 for front and 285/35/19 for Rear.
Will it rub?
Any other suggestion or comment.
Thanks guys, really appreciate your answer.
19X8.5 F
19X10 R
Will it rub?
ive ordered 19" wheels aswell. kahn rs-v 2pc, 8.5x19 and 9.5x19.
i will use 245/35 and 275/30. these are what most people with an e60 and 19" wheels get. BMW uses these tyres sizes on there 19" for the E60 and it will not rub.
HS_01,
Here is link to previous post. Some of it is in regards to 20", but has a good discussion on possible problems with larger diameter tire, and has a link that you can check your size. Off hand, I would imagine that the larger diameter size you are suggesting, may not rub, but will affect ABS, Speedometer, DTC, ...
Previous Post
A search would also get a few more previous posts.
Previous Post
