Matching Amp Wattage to Speakers?
Hi,
If running speakers rated at 50W RMS (nominal), what wattage amp should I match these up with?
An amp that does 50W RMS x 4, or an Amp that pumps a bit more juice than the speakers are rated at? Maybe an amp that does 75W - 100W RMS?
Advice appreciated
Advice appreciated
Model Year: 2010
75W+/ch would be a good start. A 50W/ch amp would have distortion at lower power levels than a 75W/ch amp. Distorted output can kill a speaker quickly. Listen responsibly with this setup, as any audible distortion would be the result of over-driving your speakers. A higher-power amp can produce better quality sound at the same listening level then a lower-power amp, if both amps are of comparable quality.
My Ride: 2008 535i:
1992 Camaro RS:
I don't remember hearing the term RMS associated with speakers.......
Anyway, I somewhat agree with vhkong:
A higher output amp would be the better choice. Just remember the following:
-Make sure the power ratings are based on the same impedance
-You have a good source (head unit)
-Check the THD rating on the amp (maybe somebody else could explain this better)
-Remember you can't turn the volume up too loud since the speakers won't handle it.
Thanks for the input!
The Alpine PDX-5, 5 channel Amp (4 channel + mono) has the following ratings:
SPECIFICATIONS
RMS Continuous Power (at 14.4V, 20Hz ? 20kHz, FULL RANGE)
? Per channel into 4 ohms (?1% THD + N) .................................................. ............................................. 75W x 4
RMS Continuous Power (at 14.4V, 20 ? 200Hz, MONO)
? Per channel into 4 ohms (?1% THD + N) .................................................. ........................................... 300W x 1
? Per channel into 2 ohms (?1% THD + N) .................................................. ........................................... 300W x 1
What do you guys think?
SPECIFICATIONS
My Ride: 2006 titanium silver metallic
Like new 41k
Cold Weather Package
I'm thinking of upgrading my system as well. I've had good luck with JL in the past. I'm leaning towards this unit:
Features:
JL Audio A6450 A Series 6-Channel Class AB Car Amplifier
Edit I see you already considered this option.
Features:
ucsbwsr
09-19-2015 10:58 AM
umichchris
09-10-2015 12:54 PM
umnitza
09-02-2015 11:28 AM
