M5 Mirrors Question
Old Nov 12, 2008 | 04:37 PM
AKAlius's Avatar
Thumbs up
Hi everyone, this is a pic of one of the M5 mirrors that I have coming to me. The donor car was a 2006 M5, and my car is a 2004 530i. I have been wanting to know if these will fit my ride. If not, since it is from a pre-LCI car and my car is a pre-LCI as well, would it be possible to make this plug n play with some sort of wire adapter? I know there is also an option to swap out the inner workings of the original mirrors to the M5 mirrors, but I think if this is possible then it would be more logical to do so.
Concept would be a set of wires with a female plug on one end, and a male plug on the other end. The female end plug would connect to the male wire harness of the mirrors and the male end would run to the female plug of the car.
Is it likely that this could be possible?
Thanks!
Old Nov 12, 2008 | 04:39 PM
Cwest's Avatar
My530I or Bruce Miranda would know what to do.
Old Nov 12, 2008 | 04:41 PM
nigxdoof's Avatar
Hey Phi, this might help.
http://forums.e60.net/index.php?showtopic=54860
I know that he did new mirrors on an older e60. So you should be good.
Old Nov 12, 2008 | 08:47 PM
tex_phil's Avatar
My Ride: 04 525i, 04 Dinan M3
I belive a number of people have m5 mirrors on pre lci. I've been looking at getting them too once my new bumper is on.
Old Nov 13, 2008 | 12:08 AM
bruce_miranda's Avatar
I don't want to sound like the bearer of bad news but here's your problem.
In pre-LCI cars the mirrors underwent a major change in 09/2005. This was not simply a wiring change but a big protocol and communication change. Up to 08/2005 the mirrors were 'dumb' and had individual wires for all the functions in the car - those individual wires were connected to an 'intelligent' door module which was receiving the BUS messages and decoding them into electrical signal pulses to be sent to the mirror.
Post 09/2005 the door module was removed completely and the functions were integrated into the Body Module and an ECU was added in the mirrors themselves. The Body Module and the ECU now communicate over a LIN Bus (single wire and ground bus). Also signal decoding is now done inside the mirror itself and thats the reason the 09/2005 mirrors have only 3 wires (power, LIN and ground).
So its not a simple question of making a wiring harness between the different version.
You could actually make a post 09/2005 car work with a pre- 09/2005 mirror but the otherway around is probably impossible without some major changes to the parts involved in the car. Post 09/2005 car to pre- 09/2005 mirrors would need to have the ECU from the old mirrors removed and hidden inside the door. Use the wires from the mirror ecu to driving the individual components of the pre 09/2005 mirror - its that simple.
In your case unless you want to attempt to build a Door Module to LIN Bus interface you're out of luck.
P.S. : Just thought of another solution provide you are happy with hacking the mirror you have. This will involve cutting out the ECU from the M5 mirror completely and attempting to build a bridging wiring harness between the door module of your car and the individual wires of the various components after the ECU. This is just a wild idea with absolutely no way to confirm if this will work. This area I thing you may have a problem with this is the mirror motor.
Your easiest solution is going to be a complete internal transplate.
Old Nov 13, 2008 | 08:41 AM
AKAlius's Avatar
Bruce, if I decide not to do the transplant for reasons of keeping the original mirrors intact for resale purpose, and buy new motors for the mirrors instead, I heard that the wires coming from the mirrors motor will have no harness on it to plug into my car door module. Is there a way I can order the plastic piece so i can make the wire into a full harness to plug into the door module?
Old Nov 13, 2008 | 09:14 AM
What I'd suggest is looking for some old mirrors on ebay or a breaker and then using the electronics for that to transplant into the M5 shell. Don't spend a lot of money on it because you'll actually be quite shocked to hear that your current mirrors have very little resale value and so it may actually work out cheaper for you to take the stuff out of what you have rather than buy new stuff.
BMW do have spares for the mirrors but even they don't sell the wiring harness as a spare.
http://www.realoem.com/bmw/showparts.do?mo...hg=51&fg=10
Old Nov 13, 2008 | 09:20 AM
AKAlius's Avatar
Ahh.. I see. That makes perfect sense. Thanks Bruce.
rorschach76
Aug 1, 2015 07:39 AM
Brada Wheels
Jul 16, 2015 06:52 AM
525d MSport
F10 Discussion
Jul 12, 2015 07:03 AM
w84me
Jul 10, 2015 10:56 AM
ST JAMES
Jul 3, 2015 07:04 PM
