M5/ M6 offsets
My Ride: 545 modded the F out
Im about to finalize a purchase from Gary tomorrow on some 166's. Clearly a newbie over here and I need some advice on exactly what the difference is and what is preferred? So far I have done nothing to my ride. Next mod is pickin up a set of coilovers. Throw whatever you can my way please.
Thanks!
Thanks!
M5 and M6 front offsets are the same: ET 12
Rears:
M5 ET 28
M6 ET 17
the 11 mm difference with M6 offset will push the wheels flush to fenders. Those with M5 offsets often add psacer to get the look of M6 offsets. Generally, if you are buying new, M6 offsets are the preferred and recc'd choice...sets that are bought used/pre-owned tend to be M5 offsets
You will be good to go with the coilovers with the M6 offset, no rubbing issues if you get the right tire sizes...here's a good tutorial on this
http://forums.e60.net/index.php?showtopic=54583&hl=
pics of each set-up and more info can be found using the upper right search bar,
GL
Gene
Rears:
M5 ET 28
M6 ET 17
GL
Gene
Rears:
M5 ET 28
M6 ET 17
GL
Gene
Rears:
M5 ET 28
M6 ET 17
GL
Gene
Thanks bro! Much appreciated!
Originally Posted by SocalE60' post='849628' date='Apr 16 2009, 02:34 PM
From all of the post I've been reading, looks like the M6 offset is what you want to get the flush fender look.
I always use this calculator, http://www.1010tires.com/WheelOffsetCalculator.asp
And yes, M6 spec on the rear will save you a 10mm spacer, but front still need 10-12mm spacer to make it flush.
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
so if we were in the market for new wheels, for example from wheelnext.com
and we wanted the m6 offset. Would it be best to just look for wheels that match for the m6 and that will give us the m6 offset that we want?
umnitza
09-02-2015 11:28 AM
