looking to upgrade rotors and brake
My Ride: 2004 530i, Alpine white, M-Tech Kit, 20" Asanti af-128 rims, Roof painted Black.
what you you guys think about these brake, rotors and the price if it good? if not what do you recomend?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT
Originally Posted by Rizbel' post='1089988' date='Jan 13 2010, 04:27 PM
Contact Nerweezy of Trinity or other forum vendors. They might have a better deall.
Any other suggestions plzz?
wow, that is cheap alright. I got my set up from r1 concept for a little more than that. Just use caution because not all rotors are created equal. The pads on the other hand are pretty reputable.
My Ride: Estoril Blue 440i GC
Model Year: 2017
Whatever way you go on your brakes, be aware that when you go from standard discs (rotors) to slotted or drilled, you will get much more noise when you're braking.
I went for EBC discs and pads - with slotted discs, advertised as quieter then drilled. This they may be, but they can generate some noise, particularly under "normal" braking. After all, when you are playing at "last of the late braker's", then you're more bothered about stopping than any noise (and your passenger's screaming will drown out any extra noise in this situation
Mike
).Mike
Mike
).Mike
I think the safest mod on brakes will be changing from 530 braking system to 550 or M5 braking system. Please note bigger rotor and a fortified brake module will result in heavier unsprung weight, i.e. worsen overall handling.
Honestly, I'm not too sure about your assessment. I'm doing a lot of research right now and it looks like the best mod is to get the Centric rotots and Hawk pads. Although the stoptech pads are looking really good too. either way, you are reducing the unsprung weight and gaining braking performance, albeit at the cost of worse wear and tear on the pads and rotors. Also, you can't turn drilled and slotted rotors, so that may be a bummer to some. But overall - especially at the pricepoint I'm being quoted (Anthony@BimmerBrakes FTW btw
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
