Installing bluetooth e60
Did you say you have the aux jack in the console? Do you also have a USB port there? (You DID say your car is LCI, so you should have one.) I'm assuming your bluetooth adapter needs both. Just plug both the 3.5mm and USB plug into the appropriate ports in your console. Which adapter did you order?
Administrator
It's definitely NOT LCI if it's a 2007. I was in the same boat because I also own a 2007. My solution was to go with the Sure board mentioned in this thread.
Administrator
ok then there probably is a difference, since i know for sure that i have an LCI ![Tongue](https://5series.net/forums/images/smilies/imported/tongue.gif)
do you know if it is possible to craft an USB port ( for power only) from the phone prep cables in the center console?
Almighty JungleBoy
Bluetooth & Cell Phone Forum
07-29-2005 11:59 PM
