iForged TPMS Sensor Adapter
Can someone please tell me what is the differences between the two adapters listed below. Which one is the correct one to use? I have the iForged Fabulous brushed finish with chrome lip (2 modular). The size of the wheels are 20x9 and 20x10.5. When I purchased the wheels it came with Nitto tires 245/35/20 and 285/30/20. The air valve was facing outward through one of the revits (nuts) that going along the rim. Now, that I have removed the TPMs from my original wheels and installed them on the iForged, the air valve is currently pointing straight up (going through the hole that lays on the inner face of the rim).
TPMS 90 degree sensor adapter
http://www.iforged.com/store/images/90large.jpg
iForged TPMS Straight Sensor Adapter
http://www.iforged.com/store/images/...aightlarge.jpg
which one is the correct one to use to make the TPMS lay flat on the rim?
Now, that my air valve is pointing straight up after installing the TPMS, is it possible that I convert it and have it go through the hole that's along the revits?
Thanks,
Thanks,
