I retrofitted the Individual Audio aka Dirac on my E61 - A first in the USA??
My Ride: Just a ‘simple’ 535i RWD, fully loaded with options but nothing particularly special.
Engine: N54B30A
In the CIC.TRC file change:
to
put the CIC.TRC file into the WORK folder of NCSExpert
Change the CIC.TRC filename to FSW_PSW.MAN
to
- File ->Load Profile->Manipulation (Expert)
- F1 (Start)
- F3 (Chassis)
- Select E60 (in pop-up)
- Select CAS
- F6 (Back)
- F4 (Process ECU)
- Select CIC (in pop-up)
- F4 (Read ECU)
- Close the NETTODAT.TRC file
- F5 (Basic Functions)
- Select coapiReadSgGetFswPsw
- Select OK
- Select OK
- F2 (Change Job)
- Select SG_CODIEREN (in pop-up)
- F3 (Execute Job)
It worked a charm and the system now performs as it should, with the right menu displayed in iDrive also
Germaniks
Jul 18, 2021 05:51 AM
Germaniks
Nov 19, 2014 12:29 AM
haugejan
10
Dec 19, 2010 01:59 AM
