I retrofitted the Individual Audio aka Dirac on my E61 - A first in the USA??
My Ride: e60 535i
to the OP or anyone else that might know the answer.
Do i need CIC for this ? Or will the old CCC system work just fine.
Also is it possible to get this done aswell with CIC and then code in bluetooth with combox on an E60.
Do you need to do anything with the wiring or just replace the components ?
If anyone has a full set for sale lemme know.
My Ride: E61 530xi 6MT
Engine: N52
I personally have the Individual audio/ , CIC and combox all retrofitted into my 2007 so that should work. The stereo system is a direct plug n play (with coding) on any Logic 7 car (hifi or base will need a bunch of wiring)
My Ride: e60 535i
I believe the Individual audio came out in 2008 which the CCC was still the NAV unit so it should work with both CCC/CIC.
I have the Logic 7 in my 2007 LCI e60. with the combox do you also get bluetooth music ? i realy want to retrofit that eventualy as its annoying me with the aux.
I'm assuming coding or finding someone to code for me shouldnt be a big deal. I have Ista and other programs so with a bit of help i can do it myself probably.
Engine: N52
Yep, assuming you have a TCU or MULF, just re-pin the connector for the combox and code it in. You'll need an E chassis combox and some custom coding (its really not that hard) since the E60 never came with it. Then ya bluetooth streaming becomes a thing but you will need a CIC to put the combox in
My Ride: e60 535i
I have no idea what TCU or MULF is, but the info is a start. I'm sure there's a separate discussion or post on this topic.
My 2009 LCI E61 came with individual audio and had M-ASK, no navigation. I retrofitted CIC but it doesn't seem to matter what head unit you have.
Germaniks
07-18-2021 05:51 AM
Germaniks
11-19-2014 12:29 AM
haugejan
10
12-19-2010 01:59 AM
