How to replace factory 4300k bixenon bulb with 6000k
My Ride: '06 BMW 550i, jet black, blacked out grills, tinted led side lights, 19" M wheels
Good morning. I would like to change my 4300k bixenon headlight bulbs in my pre-lci 550i to match my new 6000k hid fogs and 6000k led angel eyes. I know that I can buy the bulbs no problem, but how do you actually replace the bulbs? The owner's manual says to take it to the dealer to get the bulb replaced. That is crazy! Take it to the dealer to replace the headlight bulb? Yea right Anyways, if someone can post a DIY for how to replace these bulbs, I would REALLY appreciate it.
Just take the headlight off and just take out the outer panel / cover and there's the low beam bulb.
There's a DIY to take off the headlight, from there it's self explanatory.
Great! Thanks. I didn't want to order the lights, pull the headlight and find out that I had to break a seal or something and then end up having to take it to the dealer anyway.
My Ride: Original E60 Spec:
530i - Silver Grey Out, Black Dakota Leather In, Navigation Pro, Voice Command, HiFi Audio, Sports Package, Premium Package, Cold Weather Package w/ Heated Seats, Style# 123 Alloy Track Wheels, Auto AC, Power Front Seats, Active Turn Xennon Headlights,
Mods:
OEM M-Tech Front Bumper, OEM M Side Skirts, OEM M5 Rear Bumper, M5 Trunk Lid Finisher, M5 Style Mirrors, Custom Hamann Style Splitter, Custom Hartge Style Diffuser, RD Sport Boot Spoiler, LCI Taillights, Bruce Miranda's V4 LCI Retro Cables, 6000K Xenon light Bulbs, Xenon White LED License Plate Lights, 8000K HID 9006 Fog Lights, Akalius� Front Headlight Euro Overlays, Matte Black Kidney Grilles, E60.Net Clings, Debadged, Llumar Tinting "Micro Edged, 15% Rear 35% Sides,
Engine Mods:
Custom Magnaflow Quad Exhaust w/ Eisenmann Stamped 3� Tips, RPI Scoop (Red)
Added Electronics:
V1 Equipped (Hardwired), OEM Alpine CD Changer Retrofit,
Shoes:
SOLD-20" Staggered Vertini Hennesey Rims, Falcon 452's Tires-SOLD
New Shoes:
19" VMR 710 Hyper Silver, General Exclaim UHP 245/35/19 Front-275/30/19 Rear, Gloss Silver Caliper Paint Job DIY
^_____________
Retired
______________
Took Delivery 10/26/2009: LOADED! E60 M5 Silverstone II/Black, Active Seats, Comfort Ventilated/Heated Seats, HUD, Brushed Aluminum Trim,
You will need these tools:
- Torx set
- Socket rachet
- Not sure if it's a 8mm or 10mm socket ( get both to be safe)
-socket rachet extension
Prep: Tape the upper portion of your bumper where it meets with the bottom part of your headlights with masking tape so when removing your headlight you do not scratch up your nice paint.
1.Undo the top screws of headlight.
2. undo botom 2 screws of headlight. ( You will need the socket ratchet and extension with either the 8 or 10mm socket head.)
3. After all bolts/ screws are removed, wiggle out the headlight.
You will see these 2 plugs plugged into your headlight housing. Remove them. ( the bigger one is a bit tricky, you will need to slide then pull to remove it, and opposite to put back.)
4. Remove the back covering of the headlight housing to get access to the ignitor.
5. Unplug the power to the ignitor. Show here.
6. Twist off the ignitor. Arrows are printed on the igintor showing direction for removal. Follow the appropraite direction for reomval of the ignitor.
Twisting the ignitor off shown here.
And here.
7. Next remove these 2 locking pins by pulling them torwards eachother.
Shown two locking pins.
Removing the pins shown here.
And here.
8. Now you have access to the bulb to be replaced. Remove it and replace with new bulb.
9. Now reverse your steps to put back and install your headlight.
10. Repeat on opposite side.
All done.
Enjoy your new lights!!!
Originally Posted by AKAlius' post='865156' date='May 1 2009, 09:42 AM
Hi there, I dont have a full DIY, but I did snap some pics of the main things needed to do to change out the bulb.
- Phillips Screw Driver
- Socket rachet
- Socket rachet
Mods:
Engine Mods:
Added Electronics:
Shoes:
New Shoes:
^_____________
Retired
______________
Originally Posted by nigxdoof' post='865158' date='May 1 2009, 08:44 AM
Don't forget, that's D1S bulbs. Your headlight might have D2S, so always check before hand.
Originally Posted by AKAlius' post='865163' date='May 1 2009, 09:49 AM
How can you tell if your bulbs are D1S or D2S Mike? Wil it be printed on the bulb or does it look very different from one another?
If you notice on the outside of the headlight, there's a label that say D2S, but that's deceiving and seems like BMW F'd up on that when the bulb turns out to be D1S.
And yes I found out the hard way. LOL
Mods:
Engine Mods:
Added Electronics:
Shoes:
New Shoes:
^_____________
Retired
______________
Originally Posted by nigxdoof' post='865167' date='May 1 2009, 08:55 AM
Well, the one u showed, the D1S has that box on the end. The D2S does not, No way to really tell until you open up the headlight.
By "box on the end" do you mean the igniter with the "open" and "close" written on top with the arrows? D2S won't have that?
