High beam assist bmw e60
Old Sep 7, 2015 | 07:40 PM
spediegunz's Avatar
PLEASE NOTE THIS GUIDE IS FOR LCI CARS ONLY!!! And you need Xenon head lights in order for it to work.
use those part numbers to gather the 2 wires and connector you need to make this
the connector will plug into the mirror and the two wires will need to be routed to the yellow and black k-can wires located at the kgm module underneath the glove box.
you can either tap into the wires by splicing into them or unplugging them and creating a y split harness so that you don't need to cut into original wiring. which ever you chose make sure the yellow and black wires go back in to the harness and plugged back into kgm module then you can close every thing up
now that you have tapped into the K-CAN wires you need to route it to the mirror it will need to go along side the glove box up the pillar through the headliner and into the sunroof control
the Black will go to pin 1 of the fla connector and the yellow will go to pin 2, pin3 will be left empty.
Old Sep 7, 2015 | 08:02 PM
spediegunz's Avatar
coding instructions
1. Use NCSExpert to add $5AC to the vehicle order in both LMA and CAS
2. Use NCSExpert to "reset" the following modules according to the VO: FLA, KOMBI and LMA (additional coding with winkfp to update KOMBI to latest software version may be necessary, if high beam assist logo doesn't appear on instrument panel)
3. Use NCSExpert to change VA_LONGDISTANCELIGHT in the CCC_APPL to aktiv (this will give you a high beam assist on/off option in idrive settings.
Old Sep 22, 2015 | 11:42 PM
Soryn14's Avatar
My Ride: BMW e60 525Da LCI White, DPF out, Front grill black, Shadow line, license plate super bright led, interior white leds;
Thumbs up
thank you verry much for you complete diy
cheers
Old Sep 28, 2015 | 07:41 AM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Just need coding......
Attached Thumbnails High beam assist bmw e60-2015_09_26_img_0628.jpg   High beam assist bmw e60-2015_09_26_img_0635.jpg   High beam assist bmw e60-2015_09_26_img_0636.jpg
Old Sep 29, 2015 | 05:55 PM
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Coding done..... Drove onto the darkest park in town tonight and it work.
Thanks to SPEDIEGUNZ for the help.
Old Jan 16, 2016 | 11:33 PM
racere60's Avatar
Originally Posted by spediegunz
Just completed this mod details online are very little and scattered everywhere so I'll add some helpful tips. If you have a late model e60 and your rain light sensor looks round instead of square shaped, pictured in first post. You will need to tap into kcan high (black) and kcan low (yellow) twisted wires. The closest place to locate them on the lci e60 is NOT in the rain sensor like most guides suggest, but connected to the kgm module located right below the glove box. You will need to remove the roof of the passenger side footwell, tap and splice into the yellow and black pins from the left most harness and route the wires up the right side pillar across the roof liner, into the sun roof controls and finally through the tube going to the mirror. you will need to source the proper tyco contacts to the wires and also source the proper 3 pin male harness to connect to the fla female harness on the mirror. Make sure you put black in pin one and yellow in pin 2 the third remains empty. Tuck everything away and put the car back together. Finally code it and all should be working correctly.
I will update further with some pictures and coding instructions soon ....
hello I need your help. I will retrofit high beam assist (FLA). my model is 6/2005. where plug pin 1 and pin 2.
where to find yellow and black to engage (FLA).
My model is not LCI.
Old Jan 17, 2016 | 07:15 AM
spediegunz's Avatar
In your case you will use the same pins, and yellow and black wires. Only difference is you will be tapping into those wires at the rain light sensor ( rectangular box on windshield in front of the mirror) instead of the kbm module. This post has pictures of someone who did this mod and has a pre lci like yours
https://5series.net/forums/e60-parts...4/#post1552698
Old Jan 17, 2016 | 09:41 AM
racere60's Avatar
does not let me link
turbogate
Apr 11, 2015 05:02 PM
BYS2
Mar 24, 2015 03:13 AM
Sep 16, 2003 03:38 PM
Thomas the Swede
Sep 13, 2003 12:22 PM
