Help, Will the 645 Wheels Fit the 545?
My Ride: 2004 520i, mystic blue, steptronic, beige leather, pdc, bluetooth, rain sensor, BMW sport kit fitted, 18" 166 rep BMW rims , de-badged, cherished reg. chrome grill,
Originally Posted by Centurion' date='Aug 24 2005, 05:51 AM
Well, good luck anyway.
Hope this thing works out and keep us posted.
[snapback]162716[/snapback]
The offset is perfect
no problems what so ever. Your only issue may be with the tire size or maybe not. I am running 275/30-19 Rear and 245/35-19 Front. I clocked several thousand miles last month with 4 adults and a trunk full of luggage and it never rubbed once! Let us know about the bigger tires.
![Help, Will the 645 Wheels Fit the 545?-09.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/9865d1482363464t-help-will-645-wheels-fit-545-09.jpg)
Hey, Ultra, sweet looking ride!!!
I have a doubt, but i think the 275/35 tires put on a 545i with SPORT may rub due to the lowered stance (545i sport is lower than let's say a 525i sport)...
Let us know how it goes!
[snapback]162815[/snapback]
Sport or non sport makes no difference. Both bottom out in the same place there is absolutely no difference. The axle and space in the fender wells is also exactly the same. Non sport just starts out higher and the spring rate is different allowing for more travel. So actually a non sport would have a better chance of rubbing than a sport because it is more likely to reach the bottom than the stiffer sport springs.
The rear will not rub for sure. The only possible rubbing problem will be with the taller tires on the front with the wheel turned all the way to the left or right. I have less than half an inch at full lock with 245/35's so 245/40's on 19's may in fact rub at full lock.
I just went out to take a picture and I can't even fit my finger between the fender well and the tire at full lock.
![Help, Will the 645 Wheels Fit the 545?-1.jpg](https://5series.net/forums/attachments/e60-e61-parts-accessories-mods-22/9872d1482363464t-help-will-645-wheels-fit-545-1.jpg)
Thanks MMAfia?
Wow, thanks for taking that pic... looks like it's quite tight in the front at full lock... do you notice rubbing at all when turning at full lock? might just be a very very snug fit?
i think the those wheels look really good on a black e60.... i have a white one which i think will also look pretty good with those wheels.
MMAfia
My Ride: Jet Black 545i
Chi,
The only thing that you should worry about is your tire size. As pointed out here, 245-40s and 275-35s will probably rub due to their bigger sidewalls. For it not to have a chance of rubbing, go with 245-35 front and 275-30 rear. I believe BMW chose this config for the 645 due to it's bigger wheel wells.
Don't worry dude, they will fit. Those pics the guys posted on this thread already proves that. Go get some sleep, it seems as though you lost quite a bit over this wheel thing.
[snapback]162914[/snapback]
![Wub](https://5series.net/forums/images/smilies/imported/wub.gif)
Enjoy the new wheels Chi and post a picture for us
Originally Posted by ULtraPLanet' date='Aug 24 2005, 06:51 PM
[quote name='MMAfia' date='Aug 24 2005, 06:57 PM']i think the those wheels look really good on a black e60.... i have a white one which i think will also look pretty good with those wheels.
[snapback]163038[/snapback]
[/quote]Anothre benefit of these wheels is the easy cleaning. Easiest wheel I've ever had to clean - can reach almost everywhere on wheel with large brush. Enjoy the ellipsoids
bestofthebest
03-30-2015 08:12 PM
