View Poll Results: Which option do you think would look best..?
MIxed, Dash in Brushed alum/steel. Center console in Carbon fiber.
5.88%
Use only brushed aluminum or steel vinyl. Do not mix.
10
58.82%
Keep it to Di Noc Carbon fiber of a lighter color.
23.53%
Leave it as is..
11.76%
Voters: 17. You may not vote on this poll
Help me decide between Di-noc/CF and Brushed Alum. for interior..
#21
My Ride: 2005 525i 6MT
looks really good that!
Have you had the door cards off before? they are a bit of a PITA, I had all 4 of mine off at least 3 times each doing separate jobs and only realised how to refit properly on the final attempt
PS looks loads better with that cubby hole above the seat heat switches, do you only get that if you don't have full nav?
I think the cubby hole is for (pre lci) non navi. I like it. it lets me put a phone in there nicely. I dont understand car interiors with no place to put a thing with exception of doors..
#23
My Ride: 535D Tourer - Pre LCI
As ET says above Bill...I'd buy a dozen clips to have handy.
Main thing for me was refitting the rubber that seals the window, when you get the cards off, you won't be able to mount the rubber flush anymore upon refitting - I found that by removing the metal clips on the removed cards (mounted beneath the rubber), reinsalling these metal clips on the actual door, then pushing the card (rubbers) into the clips. Hope this makes sense?
Oh and you'll need some long nose pliers, when you pull the door card off (you'll need to forcefully, bottom first) theres one main clip in the middle of the door which when you pull the door card out will leave a plastic piece behind, you'll need to remove the plastic clip from the door clip and reinstall that on the card - before you refit.
Hard to describe, but once its all off, it'll all make sense
PS I did all my work without removing the airbag connectors, these are a PITA to remove without breaking and a PITA to refit if you haven't broken the clip
#24
Have you thought about upgrading your shift knob to a shorter, weighted ZHP one? I think it's money well spent, it's got a great feel. I know the thread isn't about this but I cringe thinking about how that old shift knob felt in the base of my palm.
LeatherZ: ZHP Short Shift Knob
Sorry for the unsolicited advice...
#25
as far as this weighted zhp knob..
yuck! i know everyone loves those knobs. i know! haha. i dont like the look. to plain jane and boring for my taste. ths knob i found is exactly what i was looking for. illuminated 6 speed with m logo.
i really wish it was piano black but i can always paint it! The taller shift knob on this car feels so perfect to me.. i had the old anatomic shaped knob before this newer knob in the pics. The height of the knob is perfect for the center arm rest
I have however been thinking about how to weight my current knob.
#26
i have been watching videos on youtube and googling some tips on it. i found a nice disassembly PDF on the BSW page for and audio upgrade which involves taking door cards off!
I am slightly lost on this..
Originally Posted by 1Animal1
"Main thing for me was refitting the rubber that seals the window, when you get the cards off, you won't be able to mount the rubber flush anymore upon refitting - I found that by removing the metal clips on the removed cards (mounted beneath the rubber), reinsalling these metal clips on the actual door, then pushing the card (rubbers) into the clips. Hope this makes sense?
Im going to keep looking through videos and info and attempt this soon.
I think if i can keep the airbag plugged in, i can take the door trim, wrap it and re insall without any issues.
thanks again for the heads up. im sure once its apart it'll make more sense!
-Bill
#27
it really will make more sense once its off - best of luck!!
oh!! and be careful with the tiny bolts on the back of the trim!!! they've a nasty habit of ripping the plastic off the trim which secures the back of the bolt... I ruined one piece by this method, and broke a few other (luckily still able to secure the trim upon refitting)
Tim
Tim
#28
#29
im not sure if wrapping it is an option. Getting a clean wrinkle free wrap on something that shape would be tough without distorting the brushed steel effect on the wrap..
If its been done i'd like to see some pics!
How about one of these, i wanted to do one of these but couldnt find pics in an e60 with brushed trim. the idea of the wearing alcantara bugged me as well..
#30
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
Go with brushed silver alum. for a nice contrast.
