Help with fitting CCC in E60
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys I brought a CCC unit and the large screen I take it fitting is straight forward
What do I need to do make the unit work with my car
I haven't fitted it yet I have the bracket that holds the CCC in place and front panel with double slot is there anything else I need
Thanks
Thanks
Must be some people around who have carried this out ?
Any one
Any one
My Ride: ///M5 BEAST
hey there, do a detailed search on the forum....there is tons of information on this mod out there. i performed this mod then subsequently took it to the next level and installed the CIC full system....all via information found on this very forum...
Looked around mate find more info on cic than CCC on here and the net thanks for the reply tho
much of the same information carries over...
you will need:
you will need:
- CCC Navigation Screen
- CCC Nav main unit
- Correct GPS antennae (i found mine on ebay)
- CCC Fan cable/harness...this one was hard as hell to figure out....some members made one themselves
- CCC HI iDrive controller - with some coding you may be able to use your old pre-existing "LOW" idrive controller
- Coding...i would get a software update at the dealer before starting then head over to bmwcoding.com for a tutorial on how to code and find a thread on the CCC retrofit, there it will tell you what to change and how to change it
Thanks for the that buddy a lot more helpfull
I got the larger screen
CCC nav unit
The double hole face panel
I need gps antenna
and may be high controller if I can't code mine to work
And fan harness
Is any of the mics that are shown needed at all
CCC nav unit
I need gps antenna
And fan harness
when i did my install the voice activation was never of any interest to me so i didnt even bother to research that portion of it...im sorry i cant help with that stuff...
also, dont underestimate the coding aspect of things...once you buy all this stuff it wont work automatically. matter of fact, your car wont even know its there. you will have to program the car to know that its now equipped with navigation and then program your car to talk with the new nav unit. sounds tricky (and it can be) but i dont want to scare you off. i learned how to do it and i was a novice (still am very much so).
in order to do the coding you will need a cable....read up on things over at bmwcoding.com for more information. look at the how-to-code threads....its a good start.
Thanks for all the help so far mate
I got the cable and Ncs software done few bits of coding before but nothing too major
I know I will need to add a certain code to the vehicle order
Any idea how long the coding will Take
does the ccc give voice directions if so are these from the car speakers or i need something seperate for the ccc
as i dont know what the mic is for or voice function
When I changed from MASK to CCC it was really a plug and play... For the most part everything worked without any coding. The only thing that didn't work was my SAT radio and ipod connection. The nav setup camme from Germany and perhaps I was lucky and recieved a unit that was similar to my car setup. After coding the $609 the unit got even better. There was not any special coding for the controller in my case either but I have heard that some need it. Voice guidance works great. I cannot use the voice commands. This will be a future project to see if this can be brought back into action. So in my case Bluetooth for the phone and my voice input doesn't work.. I can live with this! Fan cable is simple. PM me for instructions.
