HELLP BMW E60 MIRO 935 WHEELS !!!!!!!!
PLEASE HELLP!!! I buy this MIRO 935 wheels model for my 07 Bmw 530i and i have some big problems and i apreciatte if you can hellp me because im disperate,i install this wheels with cetral hub rings on my car directly without any modification and after that imediatly starting a vibration on my stering wheel,i make the balance for 4 times and i check the tires and evrething its ok and nobody know what its wrong!! please tell me if i need to instal them with wheels spacers because i know this miro935 its for E90 fitment ,my tires are new and are 245/35/19 front and 275/30/19 rear!!please let me know if you know somtnhing about that and what i can do
If you have the E90 Fitment, means you have the mid offset wheels. Miro make these in 72.56 hub bore. So the problem might be from your balancing. try to look for a place that offer Hunter Road Force Balancing.
Hope this helps.
D
Location: Frankfurt/Main/Germany,originally from south Italy
My Ride: 2010 BMW 530i E61, alpine white, cream-beige interior, sports-auto-transmission and a lot more-
btw: be careful parking your ride, your front bumper is dangerously close to the road curb..
My Ride: 2005 E60 523 executive
20"ASA / Bi-Xenon / Full M-tech / LED Angel Eyes / Matte Black Kidney's / LED Side Markers
You say you got the E90 offset...what offset is that? I think you need offsets between 15 and 25 or so, to be able to fit them without spacers.
spacers will not affect any vibration issues.. they just bump your wheels out.. thats not your issue, its either the hub or the balancing.. try like one member said with the road force balancing.. let us know what happens..
My Ride: Bmw 530d 2004
You said you installed the wheels with hub rings, but did they do the balancing with the hub rings or without? I'm not sure would this have any affect, but it just bumped into my mind.
To me the front wheel looks like it sits nicely, and I don't think it would sit that flush with the e90 offsets...
Your offsets are too high and you could be possibly rubbing against your struts, The Miro 935 are hub centric,
So take those wheels off and check for any damage, then find a local vendor that can get you some hubcentric 15mm spacers with longer wheel bolts. then have your wheels re balanced for peace of mind
Man I hate these posts why are middleman selling shit for our cars that dont fit? racks my brain.
Thnks to all of you for your hellp!!!!
THE OFFSET ITS OK,I CHECK IT AND ITS OK,THEY MAKE THE BALANCE WITHOUT HUB CENTRIC RINGS ON THE WHEELS ,I DONT KNOW IF THE BALANCE ITS OK TO DO WITH THE HUB RINGS ON THE WHEELS,IM GONE ORDER OTHER NORMAL HUB RINGS 74.1- 72.6 AND AFTER THAT I MAKE THE BALANCE WITH A HUNTER MACHINE FOR A 5 TIMES AND IF I DONT SEE ANY GOOD SIGN IM GONE TRY TO CHANGE THE FRONT LOWER ARM WITH BUSHINGS AND MAIBY I TRY TO CHECK ONE MORE TIME TO THE BMW DEALERSHIP THE WHEELS TO SEE IF ITS HAVE SOME ISSUES FROM MANUFACTURING AND I DONT KNOW!!
MIRO 935 MEASURAMENT Rims Size: 19 X 8.5" front & 19 X 9.5" rear
Bolt Pattern: 5 X 120
Offset: 15 mm front & 20 mm rear
Hub Bore: 74.1
Hub Bore: 74.1
