Heated sport memory seats
My Ride: 525d SE
Please can anyone help me, i have purchased some Heated leather memory sport seats and am having a nightmare fitting them and getting them working.
I have fitted the seats and when i operate the passenger seat both seats move and both heat but only the heated seat switch for the passengers side worked but this operated both seats. then i moved the switch from the passengers seat to the drivers seat it works fine but operated both sides ,still the drivers heated seat switch did not work.
i was discontenting things and somehow manged to get the drivers seat switch work for the passenger seat and the passenger switch operated the drivers seat and both heated seat switch worked. At this point i did not test to See which seat heated with witch switch because i remove the battery and reconnected it to see if the switches would reprogram. Unfortunately the lot is now back to the beginning both seats operated by the passenger switch and the drivers seat and heated seat switches do not work
Note i have not been able to get the memory switch to operate but not to bothered at this point.
Anybody any ideas??????????????
My Ride: 525d SE
Just an update I disconnected the battery and left over night when I reconnected every thing works but still the driver?s switch controls the passenger seat and the passengers? switch controls the driver?s seat. The heated seat switches work the wrong seat but both work and the memory switch lights up.
I then swapped the seat modules over even thou one had L and one had R on them. Left it over night and reconnected unfortunately the switches still control the wrong switches.
Any ideas??????????????????????????????????
Is your car RHD or LHD? (Left hand drive) What about the seats? Are they LHD or RHD? I suppose you've bought them used.
Anyways, you need to code the car in order to reprogramm the new seats.
My Ride: 525d SE
How do you code the car?????
I have had the system updated a month ago when i added the multi CD player
Dealers not much use as the say the seats were not an option on my car!!
socale39
09-05-2023 08:30 AM
