Headlight Help
Old Jan 22, 2020 | 10:54 AM
Pauls E61's Avatar
My Ride: E61 520D Auto
Default Headlight Help
Hi All
my standard headlights are absolutely shite
on the dark mornings I can hardly see anything in front of me and not enough power to light up the road markings/white lines
can anyone recommend the best method to improve or upgrade my lights
replacement bulb types for example without causing other issues like I need to get them programmed/coded to the car
i don’t want to spend too much money so the cheapest effective improvement from standard would be great
thank you
Old Jan 23, 2020 | 09:16 AM
neilv's Avatar
My Ride: E61 530xi 6MT
Engine: N52
If the lenses are cloudy then I would start with that, If not then it really just because its a standard halogen bulb. You could try a better halogen or even Xenon/Led retrofit but you would only see a slight improvement.
Honestly you are better off getting a set used set of factory xenons(projectors) and getting them installed/coded. It should only be a little more than buying new bulbs
Old Jan 23, 2020 | 11:41 AM
Pauls E61's Avatar
Ah OK
good advice. Thanks
will look into finding a used set of xenons then and hopefully make the driving experience a little easier
thanks for your reply
dwalters
Jun 12, 2013 02:41 PM
May 21, 2013 07:14 AM
higher
Nov 9, 2009 03:42 AM
gbjules
May 20, 2009 07:12 AM
artc
DIY: Do It Yourself
Jan 12, 2008 11:27 AM
