Halogen to Xenon 2005 e60
My story is pretty unique and I have used the search button on the forum and google. I purchased a used 2005 e60 that came with after marker Xenon setup. The ballast was mounted to my wheel and I had an accident which damaged the ballast. I had the wheel well repaired and next up was the light. Took it to a shop and the tech mentioned some dumb ass glued and soldered the cap and there was no way he could do the service.
So i need help with finding a good set of xenon headlights. If someone can direct me a dealer on the forum and or give me the part numbers I need it will be greatly appreciated,
Not sure I understand it correctly so currently the car came with halogen headlight but using HID aftermarket bulb? If correct you have to replace the headlight with same kind so have to use halogen headlight again, can't simply put Xenon headlight 'cuz the wiring is different (at least one ground wire not present in the halogen plug) and the light control module (LCM) is also different.
For example, my car a pre-LCI which came w/ standard halogen from the factory then when I retrofitted LCI Bi-Xenon I have to re-wired the plug then re-programmed the LCM (the computer module that handle all the lighting) ... simply fitment was zero problem as the are the same size and shape.
Stormcrow
12-01-2019 02:09 AM
