Fitting heated seats from 2009 to 2006 car
Both seats are semi electric but 2009 ones are from M model and are heated.
Ive brought the seats and DTC/Heated seats module to fit in dash.
Is it a simple swap and 2wiring from each button to seat to turn on heated seats on and off?
Anyone tried this?
Thanks
Anyone tried this?
Thanks
My Ride: BMW e60 525IA 12/2003
Hi
Sorry , it isen't "so" simpel , the heating of the seat are controlled tru signals runed over/by the K_Can_Bus wire's HIGH & LOW , so you will need to make sure these signals are availible at each seat , together with the powersingal +/- , here you will have to look at the BMW WDS ( WDS wirring Diagram Systems ).
Also the bottons for seat-heating from a E60/61 after 03-2007 ( = LCI models ) isen't the same as neede for a E60/61 build before this date also called pre-LCI models( yours is a 2006 = pre-LCI model ) , in the pre-LCI models the seat-heating bottons sit directly in the SZM modul ( in fornt of the gearlever ) , were the bottons in the LCI models sit in the cover in front of the gearlever , and the control unit/function is integrated into the KGM modul located behind the glovcompartment.
So you will need to purchase a SZM modul with the bottons needed ( 2 x hearting + DTC and perhaps PDC/RDC etc. , depending on your cars extras ) , and then perhaps run 2 wires to each seat ( K_Can_bus HIGH ( black wire ) & LOW ( yellow wire )), were to connect , look at the WDS.
Also the car will have to be coded for seat-heating afterwards !
Kind Regards
BenAnd/Denmark
Kind Regards
BenAnd/Denmark
Hi
The wires for the heated seats are in a 9 pin ( black ) connector , and is not a part of the big yellow connector.
If you at this point not have K-Can_Bus HIGH & LOW ( twisted yellow & black wires 0.35m2 ) wire to your seats ( both front seats ) , this must be done , also a power ( red/greeen ) & ground ( brown ) ( both wires 2.5m2 ) wire must be made/runned from the same power & ground wires at the big yellow connector over to this seperate 9 pin connector
Where to pin in , in the 9 pin connector , please se the wire diagram.
Sorry , don't have the part no. for this connector but try at a BMW garage.
If your lucky , no programing is needed due to the used SZM with the heating botton's should be programed for this option all ready.
Hi
Do you have the wiring diagrams?
Thanks
