Facelift turn signal to pre-face
Hey guys, I have dynamic xenon pre-face headlights, but I like face look (I mean I like the turn signal). So.. I was wondering, is it possible to fit facelift turn signal ot pre-facelift headlight. I just like this strip look and want to make it, but not sure will it fit, so I hope someone done it and share will it fit without problems or should make some glue / cutting to make it fit.
My Ride: 2x E61, 1x E60, 1x E90
Model Year: 07,07,10
Engine: N52, N54
You can use facelift headlights but it will require wiring work as well as LM2 module + programming. (if you have LM1, some cars already come with LM2). Not sure if the plastics will fit in a pre-LCI headlight. I am running 2010 headlights in a 2007.
My Ride: E61 530xi 6MT
Engine: N52
The headlight internal pieces/shrouds are completely different. Im sure with some cutting/trimming/gluing anything can fit. I doubt it will be easy and it would be 1000x easier to retrofit LCI headlights(you'll need to get a set and open them up to get the signal cover anyways)
Alaris
Feb 16, 2009 05:34 PM
