Experts knowledge needed
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
Going to replace lower oil pan due to leaks from gasket and as well as from drain bolt. This is the only place I have oil leak right know as I took care of other leaking areas.
Obviously I need to transfer the oil level sensor to the new pan and looking to the realOEM
where it says "Before replacing the oil level sensor
always note PuMA measure 29604954! "
Can someone explain what this means!
Have anyone here done an lower oil pan change on N62. I think that it does not need engine lift and subframe removal? Can someone confirm this?
Thx
Thx
My Ride: BMW 730d and BMW 525
If you search for "puma 29604954" in this forum you will find someone else has asked the same question and there is a link to download the PuMA document.
My Ride: 04' 545, 6 Spd Manual, Blk Lthr, Sport Pkg, Sport Sts, Logic 7, Cold Wthr Pkg, Full L.E.D. Interior, Red Eng. Cvr, Mtech Front Bmpr, M5 Spoiler, Matte Blk Grill, Red Caps, Slttd & Drlld Rotors, 20
Thx
Thx
I sent you a PM on a issue Im having that it seems like you have fixed before on your car. Would you be able to help me out with some advice the question is waiting for you in your inbox brother. A little time sensitive for me. Thanks again brother.
