Earthquake SWS-8XI
My Ride: Mini Cooper
I am planning to upgrade the sub under the seat to Earthquake SWS-8XI but I see that this is 2 Ohm.
http://www.sonicelectronix.com/item_...hm+SWS-8-.html
dose the 2 Ohm matter?
do I need 4 Ohm?
do I need 4 Ohm?
My Ride: '04 545i
'02 SC430
'04 RX330
you will need a 4 Ohm woofer. a 2 Ohm woofer will play a lot louder, make your amp run hotter and possibly burning it out pre-maturely. the speaker needs to match the specifications of the amplifier and i'm pretty sure the BMW amp is not designed to run 2 Ohm speakers.
BTW how do I know if the car has a sub under the seat?
My Ride: E60
Engine: N52
You can see the metal mesh screen if you look under the drivers seat from the back.
The amp is located in the left trunk panel. The thing honestly looks like two cigarette boxes. Pathetic. :thumbsdown:
My Ride: e60 525i 2005 with:
H&R sway bar, K&N air filter, sprint booster I, split-fire coil, Ferodo Brake pads, M-tech kit, black shadowline (thanks Ricky)
Pending : 19' Advan Racing RS with Re-0011 tyre + Koni-FSD with Eibach Sport spring
Looking for ?exhaust ? Denson 500 for ipod
do I need 4 Ohm?
do I need 4 Ohm?
We may not have enough power to "push" the 4 ohm
Use the 2ohm version if you are not planning to upgrade the amp. However if you are planning to upgrade the amp then check if the Amp can handle 2ohm speakers (many don't) if not buy the 4ohm version.
