E60 CIC Retrofit, USB, Combox - 2006 BMW 530i
Old 02-03-2020, 12:20 PM
neilv's Avatar
My Ride: E61 530xi 6MT
Engine: N52
Your ICOM clone; How much was it?
I'm debating if buying a clone or just having someone else do it, is more cost effective
Old 02-03-2020, 12:24 PM
TeflonDon's Avatar
My Ride: BMW 530i
I bought mine almost 5 Years Ago.. Still going strong... If you're going to keep a mid 2000 and up BMW... I think it's worth it.... I paid around $350 for mine on eBay back then... Pretty sure you can get them for around $250 - 275 with the ICOM B (Most Connector).....
I just added Wi-Fi to my ICOM last night also.......
Old 07-27-2020, 12:21 AM
Bmwpower530's Avatar
My Ride: Bmw 530xd E61
Default Ssd file
Originally Posted by TeflonDon
I'm in Gwinnett County... If you need help.... I'm local until March 31st...
I have put most of the files together that anyone with a E Series will need to complete a CIC Retrofit.... These files should also help those with NBT EVO Also.....
Folder is just a little over 11GB ...
This is because of the SP-Daten v67.0.000 - Over 8GB - Which includes - E60 - E65 - E70 - E89
hi TeflonDon, i need your help to finish coding. Ncs expert, doesnt open my ssd file, or maybe im doing somethink incorect. I apreciate any help.
Old 07-27-2020, 07:39 AM
TeflonDon's Avatar
My Ride: BMW 530i
Contact me via direct / private message.
Old 07-27-2020, 01:02 PM
TeflonDon's Avatar
My Ride: BMW 530i
Need your vin #... Sent you an email.....
Old 07-27-2020, 01:50 PM
Thanks, for replay. I sent it.
Old 09-05-2021, 06:37 AM
kirvedx's Avatar
My Ride: 2006 BMW 530XI, CIC/Combox/TPMS Retrofit (CCC M-ASK Orig)
Engine: N52
BMW CIC ULTIMATE TOOLKIT - https://cartechnology.co.uk/showthread.php?tid=63051
I wanted to get this title / thread created...
There is so much out there about retrofitting... For E60.... This was a little more difficult since I purchased a 2014 Combox....
I will be posting all kinds of things pictures.. etc for the weeks to come... My retrofit is about 50% Complete... As there's so many parts out off the car...
I will go into as much detail as possible and provide files etc...
If anyone needs any coding help.. please do not hesitate to ask... (Remote Connect via Teamviewer)
For the E60 Model... You need so many parts... I still have not connected my other antennas...Red and black... I know the black one is the bluetooth antenna.. I have a lot of pictures to take and a lot of information to source / go over ....
This will be a very detailed thread... and I will be posting complete instructions including hosting the necessary files and providing support if anyone needs help (Remotely)...... This includes coding.....
Please be patient...
In all seriousness this was harder than changing the solenoids / filters / parts on the Transmission.....
When this post is all said and done... I hope it can save someone else the countless searching and up to 50 Website Tabs that I generally have open on any single day.....
More to come....
If anyone needs any coding help... etc please do not hesitate to contact me...
Hi Teflon,
I've done my CIC retrofit - and it looks great. However, I still haven't figured out my firmware version, and still waiting on an iCOMM to do the flashing of it to C1A. Your guide for flashing is going to help me out big time, thanks for posting this.
I'm having a big issue adding my 2011 (bn2000) combox to my car's VO. I've repinned it, installed it, after already installing the CIC and default coded it. To set some basic pretense here my car is a 2006 530XI, and I was able to change the date to #0909 from #0305, and ofc add $6VA, $609. It already had $605 and $639. I want to ultimately do $644 and $6NF too, for enhanced bluetooth and smartphone prep - as I do have SOS and the antennas.
Last night I set the vin (I think, assuming tool32 worked properly, said bytes were sent) in both the CIC and Combox, but I cannot for the life of me get #0910, #0911, nor as a result $6VC to add to my VO. I continuously get #0909 or #0910 is invalid FA, and if I use #0310 (the latest date NCSEXPERT allows me to set the date to) it then says $6VC is invalid FA. I'm using sp-daten v60 from bimmergeeks, and figured it might be due to the fact that I have too low of an SP Daten.
Any idea how I might get $6VC to stick? Any chance you could link the v67 SP-Daten for me for E60 (base and e60)?
Best regards!
Old 09-14-2021, 11:29 AM
TeflonDon's Avatar
My Ride: BMW 530i
Please contact me via direct message.
Old 09-21-2021, 10:06 AM
Probation Members
LicianDom's Avatar
My Ride: 2009 BMW E61
Default Same problem with the coding combox
Originally Posted by kirvedx
Hi Teflon,
Best regards!
Hello.
I have the same problem coding the combox. Please tell me how do you solve it.
Thank you
Old 09-21-2021, 05:28 PM
kirvedx's Avatar
Engine: N52
Originally Posted by LicianDom
Hello.
Thank you
So I got my ICOM and went through the trouble of learning how to use it; getting it to connect properly, etc. When using the MOST remote connection you exclusively see the CIC/CMEDIA/COMBOX (on the MOST bus), and I am able to see the combox through INPA, WinKFP, etc. When using DCAN or DIAGBUS via ICOM you won't see the combox, but you can still see the CIC.
This still presents a problem, because while you could flash it using ICOM, you can't code it. The trick, I found, was leveraging a virtual VO (i.e. tell NCSEXPERT that your car is a E90, rather than an E60 - as an E90 knows about a combox and can be configured rather similarly to an E60.)
The way to do this is via an SSD file. The steps can seem tricky, but it's straight forward (I'll post the screenshot of the post from bmwcoding.com - which was down at the time I wrote this post, the whole site, making the files unavailable):
  1. Get your VO set for a CIC (#0909, $6VA, $609), then default code your CIC (in your E60, as normal for an E60). You could go ahead and set options through a manipulation profile too, but you'll exclusively get to do this in a few steps so I'd just hold off on that anyways. If you're going to flash your CIC, might as well do that first, then default code it (you'll have to anyways).
  2. Using NCSEXPERT do a typical read of your "E60" VO (and CAS coding) and back up the trace file:
    1. Load NCSEXPERT, navigate through File->Load Profile->Factory Coding (Expert)->Start (F1)->Chassis (F3)->E60 (In pop-up)->CAS (Resulting pop-up).
    2. Once the main display populates with your VIN and FA/VO, you have a .TRC file you can back up; do so.
  3. Similarly, do a read of your CIC coding for a 18kb file and MAKE 2 COPIES (1 to keep forever, 1 to utimately modify).
    1. Load NCSEXPERT, follow the steps in 2.1, and then BACK (F6)->PROCESS ECU (F4)->CIC (In pop-up)->"OK" (the CXX referenced in this pop-up is not your firmware version, btw)->Change Job (F2)->CODIERTEN_LESEN (In pop-up)->EXECUTE JOB (F3).
    2. You'll get a 18kb FSW_PSW.TRC as normal, but its exclusively the CIC. Make 2 backups of this file. The CXX file referenced under "Get Coded" and "JOBNAME" in the main window now reference your CIC's current firmware version.
  4. Now, leveraging an SSD file tell NCSEXPERT you are working with an E90 that's got a VO with as similar as features as you can put together for your car (to make it easier, but it won't matter too much) and default code the CIC and COMBOX to work together properly in this "E90". Your CIC will no longer work properly in the car (an E60), but the combox and the CIC will work perfectly together (just, with the CIC coded for an E90...we're getting there!).
    1. This is similar to how you would default code any module, just instead of reading from the car's VO (F3), read it from the SSD file instead:
      1. How to read from an SSD file will go here (step 4.1.1)
    2. Code the COMBOX first, then the CIC.
      1. It's the same as 3.1, using 4.1.1 in place of 2.1, but with the Change Job (F2) step followed by Select SG_CODIEREN, instead of CODIERDATEN_LESEN.
  5. In NCSEXPERT, still reading the VO from the SSD file (4.1.1 in place of 2.1), do a read of the codings (3.1) of both your CIC and COMBOX.
  6. Now, using notepad++, open both the E60 and E90 CIC trace files, performing the following steps for each file:
    1. Press ctrl+f
    2. Click the replace tab
    3. Near bottom, in search mode select extended range (\n, \r, \t, \0, \x...).
    4. Make sure Wrap around is also selected
    5. For Find, enter \r\n\t
    6. For Replace, enter *
    7. Press ENTER
      This will cause all option values to go up onto the same level as the option keys, separated by an asterisk
    8. Select EDIT, then Line Operations, then Sort lines lexicographically ascending
      This will cause all options to go into alphabetical order
    9. Back in the find and replace window (Repeat steps 1-4):
      1. For Find, enter *
      2. For Replace, enter \r\n\t
    10. Press ENTER
      ​​​​This will cause all keys/options to display as normal, simply sorted alphabetically (you can code modules like this, with sorted MAN files!)
  7. Now, spend some hours going back and forth between the E60 and E90 versions of the CIC trace file (as you did the aforementioned process to both), and change any E60 Keys that the E90 trace file also has for the CIC regarding the COMBOX, to match the values of the E90 trace file within the E60 trace file. Similarly, add any keys that the E90 has exclusive to the CIC for the COMBOX that doesn't exist in the E60 trace file - to the E60 trace file.
  8. When you're confident that step 11 is done: rename the E60 trace file to FSW_PSW.MAN - and using NCSEXPERT in manipulation, but without an SSD file (so as an E60, reading from the VO [F3]): [[b]IMPORTANT] CODE ONLY THE CIC!!! DO NOT WRITE TO THE CAS NOR TO ANY OTHER MODULE, ONLY TO THE CIC!!!
  9. Now, your CIC will work in your E60 again, and the coding/settings for the COMBOX and for the COMBOX in the CIC are correct so that the COMBOX will work as well.
  10. Any time you default code your CIC from your VO, you'll need to rewrite the coding file you created back to your CIC. You won't ever have to worry about your COMBOX because your car doesn't know you have one - and never will. This is necessary because the coding the CIC will get by default will be for a CCC Navigation, and will never include a COMBOX (but rather a TCU/Mulf). The car doesn't need to know these settings for the CIC and COMBOX to work together properly - but the CIC does need them for them to work together properly. The gray area here is obviously that the COMBOX is leveraged through the CIC - NOT the car.
Here's a link to a video that explains how to use a SSD file:
https://drive.google.com/file/d/16WO...2XSrMPQpH/view
The screenshot of user Vortex's post from bmwcoding.com is attached below, along with the files he's shared (E90 SSD, codings from E90 CIC/Combox, merged coding for E60 CIC that is paired with a E90 coded Combox).
I'm mid-process of coding my CIC/Combox. I've confirmed C1A firmware and am troubleshooting potential "glovebox" USB issues as the software patcher file on a thumbdrive doesn't seem to trigger a reboot. I'm guessing my China cable/port needs some tweaking - or I'm going to have to flash in expert mode to undo script activation or some already patched varient of the firmware (not likely, doesn't seem like it). When I finish I'll share my specific files, and post a link to my write-up that will detail the stuff that's hard to find or doesn't exist, while only referencing the stuff that is all over the internet, providing a nifty post I'd hope that doesn't just flood the net.
Hope this helps.
Screenshot of the bmwcoding.com post (website is down)
File Type: txt
E90.SSD.txt (307 Bytes, 339 views)
File Type: txt
File Type: txt
File Type: txt
Last edited by kirvedx; 09-26-2021 at 06:01 AM. Reason: Corrected the find/replace content for sorting TRC files when merging, added some clarification and cleaned up the post a litle, also adding other files from bmwcoding.com for reference as promised.
The following 2 users liked this post by kirvedx:
Arbuz (05-09-2023), HankReardon (07-25-2023)
Quick Reply: E60 CIC Retrofit, USB, Combox - 2006 BMW 530i
