Dropping the Car
My Ride: Volvo V70 D5 Summum
Resently owned a
530D -05 Orentic Blue
Sport Seats and Sport steering wheel.
OEM Sprt pckage springs ?
OEM M tech springs ?
Eibach or H&R
Planning to keep the std shocks,
Have anybody dropping figures and inputs, ?
Eibach or H&R
Aftermarket is good way to go here.... Bot of those drops 30-35mm and are good choice.
OEM sport will drop 20mm
However more conserned about using standard shocks.. Not good if you like to maintain premium quality ride feeling and not bumpy ride
Yeah it is best to save up and do struts and springs..reminder each time you go to replace either or you'll need an alignment eachtime. Koni Yellow or Billsteins in combo with H&R or Eibachs will work great
Resently owned a
OK but have you some feeling abaut SPG springs or M tech less bumpier with std shocks vs H&R.
Looking on oictures SPG seems to lower a little more in rear vs M-Tech?
Not sure about that, I guess sport and M-tech shock are same? Can be verifyed from realoem by comparing part numbers....
However lowering should be same on those 20mm.
Don?t have any experience about std shocks and sport/m springs.. I think it?s very uncommon combo. Better option would be to find sport/m shocks and h&r or eibach springs
