DIY (Home made) Ram Air Scoop
#31
i still stand by my original statement. rpi spent tons of money on r&d, so much so, that other companies like afe copied them and started making scoops. now people like you fabricate your own version and hope that it makes the same amount of power. props to the op for actually making a scoop out of alumium rather than cheap home depot crap but i would still rather buy my scoops from rpi
#32
Hahahaha wow, it was never an attempt on behalf of me to take anything away from the originality and r&d for the product they came up with. I can appreciate that as well as your comment. But what are you saying, if something has already been made and mass produced that no one has the right to try and do the same? I simply did what I did for personal pride and satisfaction of knowing that I could build it. It's not like I decided to sell everyone in here on what I did and start mass producing ram air scoops. I'd never do that or imcourage that. But hey, you have an opinion just like everyone else, it's cool.
Everyone has their opinions, in the end it's all about the MONEY
#33
My Ride: check siggg
#34
I'm not disagreeing with you, but my opinion is that RPi spends all that money on research and development because they had to COME UP with the whole design of the RPi scoop. IF you create a direct copy of what has already been engineered, you don't necessarily create losses in the actual performance of the product until you start cheaping out on parts.... with the RPi scoop, there are no moving parts. The thing was engineered to move air, deflection, low pressure, Bernoulli's Principle, it won't matter, as long as your angles and dimensions are fricking on target, YOUR FINE! aerodynamically the thing will perform JUST like the RPi. Now, if you go the route of forming it out of Plaster O Paris, now your talking about major CG issues... How often do we use the the chinese equivalent of a product only to find that not only was it cheaper but it also out performs the original "3M design"? Come on, we are talking about a piece of metal with a few precise bends in it...
#35
You can't corral my argument for RPi scoops and direct it towards other applications. Obviously each application of a product has it's own requirements. You don't see me arguing my point in the wheels topics on this forum do you? I DO specialize in Aircraft mechanics, therefore there is quite a few things that I CAN argue and confidently state in regards to the aerodynamics of a piece of metal, especially in as minimally stressed an environment as that R&D'd RPi scoop you put so much faith in. Aircraft engineers may be the most anal when it comes to coaxing physics and aerodynamics to respond with a man made machine, and I can tell you straight up, if you don't have faith in aircraft mechanics, don't fly airplanes! That is why Airframe & Powerplant mechanics are the only Federally tested & licensed type of mechanic in the states. We (hopefully) know our stuff (A&Ps on this forum, chime in!)
#36
You can't corral my argument for RPi scoops and direct it towards other applications. Obviously each application of a product has it's own requirements. You don't see me arguing my point in the wheels topics on this forum do you? I DO specialize in Aircraft mechanics, therefore there is quite a few things that I CAN argue and confidently state in regards to the aerodynamics of a piece of metal, especially in as minimally stressed an environment as that R&D'd RPi scoop you put so much faith in. Aircraft engineers may be the most anal when it comes to coaxing physics and aerodynamics to respond with a man made machine, and I can tell you straight up, if you don't have faith in aircraft mechanics, don't fly airplanes! That is why Airframe & Powerplant mechanics are the only Federally tested & licensed type of mechanic in the states. We (hopefully) know our stuff (A&Ps on this forum, chime in!) ![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
socale39
09-05-2023 08:30 AM
rackhacker9275
05-19-2015 02:42 PM
