DEI Shock Sensor to OEM alarm
Anyone do it? How hard is it....? The original link where I found this. http://www.e90post.com/forums/showthread.php?t=45815.
My Ride: 04' E46 325i Sold
05' E60 53oi Sold (tranny issues)
08' E92 328i coupe 6spd MT (Current ride)
ive seen this done to e46's just like it says on the thread.. it is possible plus i really want this for my car.. but yeah any body wana help out
Engine: N54
Is there a manufacturer site for this thing? My googlez failed - just a bunch resellers and forums come up.
Engine: N54
Engine: N54
I was able to do some reading up on it. I ordered a couple so I'll check it out.
Nice keep us posted and I do remember the sensor it was the size of a tic tac box but let us know how it goes !
My Ride: '04 530i 6MT
'04 Audi S4 6MT
What makes you think our E60 is any different from an E46? All they are doing in that DIY is tapping into the wire which alerts the factory security system of a intrusion. When the shock sensor detects a shock, it will show either a 12v signal or ground at the wire which is tapped into the motion sensor. The factory security computer then sees this signal as a detection of motion inside the car and triggers the alarm. This is not any different from how any other alarm works. Infact, DEI makes a kit which allows for any aftermarket alarm to communicate with the E60 CCM through the can bus lines, this would essentially make adding an alarm almost plug and play.
