Cruise control Distronic Stop & Go retrofit
My Ride: E61 535d carbon black m-kit panoramaroof with beige nasca interior and wood trim. 172m rims. DimSport Race, SB, SAT
Have a 2007 535d E61 LCI and wonder whether possible to retrofit the Stop & Go cruise control (Tempomat)? Anyone have any experience with this?
My Ride: BMW E61 530xd 2007 LCI Touring
I'm looking for a car in Germany now and keep in mind if this function will be missing to add it myself. It seems not so hard. On ebay you can find radar main and 2 additional things (like mini-sensors) for something else.
My Ride: 2008 550i M-sport, retrofitted heated M-sport steering wheel with paddles, Sport-auto transmission
I dont recall hearing of anyone doing this retrofit. That being said, someone always has to be first - right? Anyway, keep in mind for a retrofit like this that you will need a cooperative dealer or programmer to assist you, as you need to have a modified "vehicle order" that basically tells your car that it has this function when it's being programmed...
Forum member Benand has done this and it`s not as easy as you all think it is, theres no official retrofit for it so getting it coded will have to be done by your self, the dealers wont have a clue.
For a 2007 car you need ACC2 (the radar head + short range sensors behind the bumper), you probably do not need the brake hoses changed as you already have DSC8Plus with built in pressure sensors. It is definitely some work behind, building the wiring looms, identifying where to tap into bus wires, doing the final coding.
Also when you buy a used sensor they are sometimes offered without the holder. To adjust it within the holder the dealer needs laser guided equipment that needs to be ordered from a central depot and this adjustment is charged $$$.
If you want to install it clean, you need to dismantle half of the car, let alone the power has to be drawn from the rear junction box.
TexaZ3
05-06-2015 09:54 AM
