Couple of coding questions
My Ride: 2004 E61 530d Sport
I'm looking to code out the passenger seat occupancy sensor using NCS as i'm fed up with it randomly failing. I've tried a bypass thing but you always have to have the seat belt clicked in which is annoying !
What i'm worried about is, if i code out the sensor, will the passenger airbags and pre-tension seat belts work in the event of an accident ?
Could the passenger seat belt detection be coded out instead ?
Also, does anyone know if you can code the auto wipers to remember to stay on or off after turning the ignition off ?
rizwan1377
04-05-2015 05:22 PM
