Coded some extra menu options.
Old 03-19-2011, 11:37 PM
  #211
BLooD's Avatar
Originally Posted by BlaSTiWi
I finally got around to run the wires from the int. mirror -> KGM pin #44 & #45 behind the dash and now I got my M5 mirror to dim too ... kinda of cool when it activates since my M5 mirror has frame-less glass so around the edge stay as is and the rest inside the middle darken.
Tkx so much for the info BLooD
That confirms my suspicions blast, thanks for that. I will need to do this as well then.
Which pins did you use on the mirror?
Old 03-20-2011, 05:21 AM
  #212
NoQuarter's Avatar
Engine: N54
Originally Posted by leceur
Changed DAY_RUN_LIGHT -> aktiv in CAPPL. The other 2 functions are not there but when I look in my original full TRC file they are, so they must be in an other module. My car is from Sept '06 so I might or might not have the LM2. Any way to find out?
TIP:
All my trace files are read and saved in a folder on my Windows OS. I allow Windows to index that folder for search functions. When I browse the folder, I enter a term like "DAY" or "TAG" in the search window and get a list of every trace file that contains that entry.
Old 03-20-2011, 06:43 AM
  #213
BlaSTiWi's Avatar
Originally I thought those 2 wires related for each mirror, and only tested one at a time and didn't work. Turned out from WDS & various info they related:
Code:
Int. Mirror pin #5 -> KGM pin #44
Int. Mirror pin #4 -> KGM pin #45
GL BLooD!
Old 03-20-2011, 09:56 AM
  #214
BLooD's Avatar
Code:
GL BLooD!
Are the pins empty in the KGM connector? and which connector is it on the module, also how do you take apart the mirror housing or is it the mirror itself?
Old 03-20-2011, 10:27 AM
  #215
BlaSTiWi's Avatar
Yes mine were empty in the KGM plug, it was the right bundle plug when you face the mounted module.
I didn't take apart any of my mirrors. I just ran 3 wires thru the left pillar for the power, ground & LM and ran 2 wires thru the right pillar to the KGM and all those 5 (plus 2 for the alarm clown nose) goes into a 10 slot (2 rows of 5) plug on the base of the int. mirror.
The int. mirror that I got from the donor car itself has a full featured one that has garage remote, dim, & compass.
Old 03-20-2011, 10:28 AM
  #216
BLooD's Avatar
Sorry ment the interior mirror, how does it come apart?
Old 03-20-2011, 10:44 AM
  #217
BlaSTiWi's Avatar
I didn't split open the int. mirror housing, just split the base cover (on the windshield) and there's that 10 slot plug tucked in where the metal arm pivot/rotate.
Or you mean apart off the windshield? To take it off the windshield I just rotated the metal arm of the int. mirror 'bout 45 deg. counter clockwise to release it.
Old 03-20-2011, 11:59 AM
  #218
BLooD's Avatar
OK think I got it, the 10 pin plug housing in the mirror base, the two halves just break open?
Old 03-20-2011, 01:14 PM
  #219
NoQuarter's Avatar
Engine: N54
yep - that plastic cover just splits open right down the center.
Old 03-20-2011, 01:24 PM
  #220
BLooD's Avatar
Chears dood, finally the last piece of the puzzle.
Quick Reply: Coded some extra menu options.
